09-22-2010, 09:46 AM | #1 |
53 gmc cowl vent leaks need help!
Is there anyone who has had this problem and knows how to adjust to stop it...have a new gasket and everything looks fine...but water just pours in around the vent at the back portion...any help would be appreciated...about to the point to seal it completely.
09-22-2010, 09:55 AM | #2 |
Re: 53 gmc cowl vent leaks need help!
Is the drain tube clean and working? a lot of guys who "clean up the firewall" eliminate the drain tube from the vent that goes through the firewall and the water ends up dumping on the floor. I haven't played with one in years to try and adjust it so I'm not much help there at the moment.
09-22-2010, 09:57 AM | #3 |
Thanks for answering...yes vent tube is clear...it just seems that when lowering the vent it contacts the front before the rear..and I can find no adjustment to correct it?
09-22-2010, 10:12 AM | #4 |
Easy. Just don't drive in the rain! Seriously, though sorry I can't help.
09-22-2010, 02:58 PM | #5 |
How about building up the gasket in the rear - maybe put some kind of shim or spacer under it?
Ray |
09-22-2010, 05:57 PM | #6 |
Mmm...tried that and no help...its almost like the bottom gasket is too short..I looked in classic and it shows a foam gasket that was supposed to be original and then aftermarket....I think mine is aftermarket rubber...so thinking of trying the orignal type one next...Tim
09-22-2010, 09:10 PM | #7 |
I tried a few of them and ended up using the one from Steele Rubber and it seems to seal the best.
I am sure you had all of the bolts out and adjusted it to fit and make sure the lever was over center. I ended up putting a electric motor on mine to open and close the vent and it seemed to help with the pressure to hold the vent down.
09-22-2010, 09:25 PM | #8 |
Yes..tried all adjustments...afraid to go tighter or bend hinges etc...I found the steele rubber site...got another brand on the way...if it does not work..will try your suggestion...thanks...Tim
