Old 09-24-2010, 03:13 PM   #1
Mattman2010
Mattman2010's Avatar
Gauge Cluster questions
My truck doesn't have the gauges, it has the lights that turn on when something is wrong. My parts truck on the other hand has the gauges,and I want to swap them into my truck.
The clusters
Now, I noticed that the pattern of the plug is not the same.
My Truck
Parts Truck
What do I need to do to be able to make the gauges work in my truck? Do I have to swap the whole entire wiring harness inside the cab? or do I just need to cut all the wires and wire in the plug from my parts truck into my truck? I am not sure if the gauges work or not, so I would hate to swap the harness and then find out the gauges don't work. How could I go about testing them before I fully install?
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 09-24-2010, 03:49 PM   #2
Jonboy
Slots go on anything!
Re: Gauge Cluster questions
You can use a paper clip (or equivalent- there is actually a tool to use) to detach the wires out of the plug, and move them to your desired location. The colors should be the same depending on what they are used for, but they are just in different locations on the plug. Make sure you use the proper senders for the gauges (they are different).
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 09-24-2010, 03:59 PM   #3
Mattman2010
Yeah the engine I have in the truck came out of the truck with the gauges, and my lights are on dem because the sending units are wrong. I just want to run the gauges because I can know more of what is going on better than some lights.
Build Thread
Build Thread
Thread
Old 09-24-2010, 04:44 PM   #4
Mattman2010
So I just went down to my grandpas shed and looked at the wireing of both trucks, and the parts truck (The one with the gauges) has double wires on some of the connectors, while my truck does not. So to me it doesn't look as if it is as simple as swapping the wires around to be the same as the other connector.
Build Thread
Build Thread
Thread
Old 09-24-2010, 09:25 PM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
You can always swap out the harness's as well. Tedious work but in the long run you won't be wondering if it's gonna work or if it's gonna "SMOKE"
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
