Old 09-25-2010, 03:59 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Rear end I.D. ??
Parting a cheyenne 20 longhorn and just wanted to make sure this was or wasn't worth grabbing. Any info is appreciated. I assume it is non posi? (i don't mess with many 3/4 tons)Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-25-2010, 04:43 PM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: Rear end I.D. ??
That's an HO52. It's commonly referred to as an "Eaton" however I believe it is an Eaton-type rear that was manufactured by GM.
They're good rears from what I can tell by reading. Some 4-wheelers still use them.
The most "highway" ratio that was available was 4.10 (although there's reports of custom made 3.90s around at one time) so that limits their appeal to a lot of people.
They were available with posi ("No-spin") and those are desirable. I don't know how to tell the posi by looking at it.
I have one in my C20 and I'm sticking with it...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 09-25-2010, 08:17 PM   #3
raycow
I like these rears. They are strong, last almost forever, and IMO are easier to work on than the 14 bolt which replaced them. Their only real disadvantage is the 4.10 gearing, but if you have an overdrive transmission there is no good reason not to use one.
Ray
raycow is offline   Reply With Quote
Old 09-26-2010, 12:22 PM   #4
too much stuff
Roadtrip!
Any way to tell if this is a posi from these pics? I can't turn the rear over...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 09-26-2010, 01:48 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Does not look like a posi to me and you would have to pull the carrier out and split it to actually see inside of it(however it has been awhile since I messed with one).. They are strong rear ends but seem to be a p.i.t.a. to find brake parts for.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-26-2010, 02:13 PM   #6
raycow
Yours looks like the ones I have worked on that didn't have posi, but I have never had one with posi to compare it with.
To find out for sure, you will need to lift one wheel off the ground. Make sure that the parking brake is off, if it has one, and that the driveshaft is either disconnected or free to turn.
If the wheel will turn by hand, you have an open rear. Even if you can't turn it, there should still be some free play in the wheel. If yours won't move at all, the brake shoes may be frozen to the drum. The only way to find out then would be to get the drum off.
Ray
Old 09-26-2010, 02:37 PM   #7
too much stuff
Roadtrip!
Ray
The rear won't turn at all. Been sitting for 25 years with no rear wheels. The brake drums are REALLY stuck. Thanks for the help. Eric
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 09-26-2010, 03:01 PM   #8
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
That oil looks like mud. Ick.
It looks like an open diff to me. In the last picture, there's a window in the carrier just below the ring gear. It looks like there are spider gear teeth in that window. If so, it's definitely an open diff. If the window has shiny steel in it, it's a Detroit No-Spin (aka Detroit Locker).
FWIW, they never put a posi in these rear ends; only a locker.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
