Old 09-25-2010, 06:20 PM   #1
newbraunie
newbraunie's Avatar
Truck won't start!
Parked truck about 2 weeks ago, was running fine with no problems. Went to start it today and it won't start. Went down the basic diagnostic line of fuel, spark, air and compression. Found out no spark is the problem. Pulled spark plug and grounded while turning over, no spark. Have a V-8 with HEI. Checked wire to dizzy and have full 12+ volts (yes the resistor wire has been removed and repalced with 10 gauge). Going through some other threads about HEI issues my first thought is to replace the module. Am I on the right track? Anything else I should check? Is there a way to test the module? I hate to just start replacing stuff hoping to nail the problem. Any suggestions would be appreciated!
newbraunie is offline   Reply With Quote
Old 09-25-2010, 06:21 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Truck won't start!
I am almost positive that any parts store can test the module. Call before you take it in.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-25-2010, 07:29 PM   #3
newbraunie
newbraunie's Avatar
Re: Truck won't start No spark?
Just got back from Auto Zone, module tested as good. What next? Coil?
Old 09-25-2010, 08:01 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Yep, the coil is a good place to go next, but first check the distributor cap and rotor?
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-25-2010, 09:24 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Sometimes it's cheaper and easier to go to a salvage yard and see if you can find a good used one. I paid $20 for one 10 yrs ago and $40 for a six cylinder hei couple of years ago. Both in good working condition. I did have to relube the six cylinder one, though.
68gmsee is offline   Reply With Quote
Old 09-25-2010, 10:26 PM   #6
72lb4x4
Shoot some carb cleaner or B12 in it and crank it.
72lb4x4 is offline   Reply With Quote
Old 09-25-2010, 11:11 PM   #7
rsavage
rsavage's Avatar
Are you absolutely sure it is lack of spark? If you have been cranking it and there is no strong smell of gas or the plugs aren't wet, you could have a carb float bowl that has dried up while it sat along with a weak fuel pump. Pour a little gas down the throat of the carb and see if it fires up. Sometimes it is hard to see an arc especially in daylight. Keep us posted.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-26-2010, 12:04 AM   #8
llowlife
Check the wires from the pick up coil for breaks. Shouldn't happen from sitting but I've seen weirder stuff. Moisture in cap...spark jumping from the center electrode to the shaft of the dist through the rotor. Check for carbon tracking
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
Old 09-26-2010, 12:28 AM   #9
Notrodder
You can check for spark by putting a timing light on it.
Notrodder is offline   Reply With Quote
Old 09-30-2010, 11:43 PM   #10
newbraunie
newbraunie's Avatar
Replaced coil, that was the problem. Truck is running great again!! Thanks to all for the guidance.
