Old 09-28-2010, 10:31 AM   #1
PapaBo
PapaBo's Avatar
Max tire with 6" lift/axle width
hey guys ive been searching the threads for a couple days and i cant seem to find what im looking for. whats the max tire you can put on with a 6 inch lift without trimming? ive been restoring a 83 chevy k20 and i swapped in a dana 60 front axle, i noticed the front dana 60 axle is approximately 3 inches wider than my 14 bolt... is that normal?
PapaBo is offline   Reply With Quote
Old 09-28-2010, 12:17 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: Max tire with 6" lift/axle width
I believe 35" tires will fit with 6" lift....
As far as the track width being different, yes this is typical.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 09-28-2010, 12:26 PM   #3
PapaBo
PapaBo's Avatar
do you think 37's will fit?
Old 09-28-2010, 03:10 PM   #4
LiveAnimals
LiveAnimals's Avatar
It all depends on what you plan on doing with the truck. Is it a wheeler? 35s will give you a ton of room for articulation I've seen 37s and even 38s on a 6in lift.
6in lift 37s on a 16.5x8.25 wheel
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 09-28-2010, 03:15 PM   #5
Prerunner1982
Well there you go...
And that is a nice looking truck.
Jon
Oklahoma Roll Call
Old 09-28-2010, 03:16 PM   #6
PapaBo
PapaBo's Avatar
i plan on it to be a daily driver and go wheeling on the weekend but i dont want to cut the fenders up since i just painted it lol i know a true 4x4 has different tracs for stability and so one wheel never goes in the same rut but seeing as i drive the highway quite a bit would it cause any problems to leave the tracs different or would it be better to add wheel spacers to narrow the difference in widths?
Old 09-28-2010, 03:20 PM   #7
Prerunner1982
Here is a good thread at CK5.com..
http://coloradok5.com/forums/showthread.php?t=170627
Jon
Oklahoma Roll Call
Old 09-28-2010, 07:40 PM   #8
Davidmichael
Davidmichael's Avatar
If your going to wheel it at all, just go 35's. I run 36's and I already mangled my drivers side fender a bit, and now it rubs even on the little grades.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 09-28-2010, 10:57 PM   #9
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
I had a 79 Blazer with 36" Swampers on 4" suspension and 3" body lift with no rubbing issues. I only used it on the pavement but clearance was never an issue. Keep in mind that not all listed tire sizes are entirely accurate. Some 36" tires are actually taller, some shorter, etc.
TheWhiteElephant is offline   Reply With Quote
Old 09-28-2010, 11:01 PM   #10
PapaBo
PapaBo's Avatar
thanks for the help everyone, i think im just going to get some 35" BFG mud tires i just have one more question i need answered! with the trac of the front axle being wider than the rear is their any disadvantage to it?
Old 09-28-2010, 11:14 PM   #11
TheWhiteElephant
God is good!
No disadvantage. This is actually normal for these trucks. It's the way they came from the factory.
Old 09-28-2010, 11:15 PM   #12
chevyman95
chevyman95's Avatar
6" lift with 38.5x11 boggers
chevyman95 is offline   Reply With Quote
Old 09-29-2010, 11:06 AM   #13
Prerunner1982
The different rack width is for one so the tires do not follow the same imperfections in the road, however it also helps off road (mud) because the rear tires do not follow the exact same path as the front giving them some fresh earth to get traction on.
Jon
Oklahoma Roll Call
axle, dana 60, lift, tire size
