09-27-2010, 11:18 PM | #1876 |
Re: What did you do to your truck today?
Today I started building 2 solid aluminum ball bearing watts link center sections. One will be mine and one will be Lukes.. (frenchblue72)
Then I got some more work done on the drip rail shave.
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
09-28-2010, 10:38 AM | #1877 |
C10 CLUB Y QUE!
I finaly got 700r4 up and running yesterday. And today will finish power door lock on passenger side. And. I'm hoping to see if I have enought metal to start working on the bed
Posted via Mobile Device |
09-29-2010, 02:07 PM | #1878 |
C10 CLUB Y QUE!
Finish both doors with power Door locks
09-29-2010, 02:50 PM | #1879 |
Installed the 78 front suspension.Waiting on captfab to send me the p/s adapter.
09-29-2010, 04:42 PM | #1880 |
Never Ending Projects
Monday evening I put my valve covers and air cleaner on.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
09-29-2010, 08:26 PM | #1881 |
Fabbed up the rear bumper brackets and a hidden reciever hitch today, I did not have room for a class 3 hitch between the bumper and bed. I used the smaller one should be fine as I do not plan to tow anything over the 4k rating the reciever has, I could have bought the brackets from LMC for 98$ plus their bend you over shipping but...I wanted the bumper tucked in and higher than the factory mounts them
09-29-2010, 09:28 PM | #1882 |
Check The Champ, Demonstrator
Excellent Idea!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
09-29-2010, 09:31 PM | #1883 |
Started fabricating the exhaust system. 2 1/4" OD out of the manifold to a Stainless Dynomax muffler the sales rep left behind.
09-29-2010, 10:47 PM | #1884 |
Redneck Hillbilly
YES!!! Love those air cleaners! The valve covers look pretty sic too. Last edited by fryer1979; 09-29-2010 at 10:47 PM. |
09-29-2010, 10:52 PM | #1885 |
installed the fast ez efi kit
09-30-2010, 10:37 PM | #1886 |
Installed my p/s adapter and prepped it for welding.
10-01-2010, 01:33 AM | #1887 |
I cut out the trans cross member in my daughter's 60 GMC to put a Turbo 350 behing the big six..
http://www.facebook.com/MacDonaldRac...ckTeamBcCanada |
10-01-2010, 02:07 PM | #1888 |
Hey Legend nice build on #72 you put allot of work in to it thanx for sharing the pic's if you have pic's of your daughters 60 GMC when it's done I would like to see those also.....Vernski
10-02-2010, 11:29 PM | #1889 |
painted the remaining two center caps and got one coat on the wheels before it was too windy. got the bumper scuffed and primed for paint on tuesday. Located the two tires i'll run on the front, i'll get those mounted tuesday. taped the roof off for painting, maybe sand and prep tomorrow.
Build Thread - Papa's truck build up |
10-03-2010, 02:49 AM | #1890 |
nothing major...chrome trim on wheels. but boy did it make a difference in appearance!
10-04-2010, 08:40 PM | #1891 |
Pulled out all the bed wood, was Pine that was faded out. Was going to replace it with Oak that I have that is rough sawn, after I cut to size and plane, stain and coat with lots of varnish, but also have a nice supply of Eastern Red Cedar that has been drying for a year.......so trying to decide if the cedar would look good in it. Tomorrows plan is to clean all the exposed frame and rear end, prime and paint.
10-04-2010, 09:09 PM | #1892 | |
10-06-2010, 03:29 PM | #1893 |
1961 crewcab
busy today, put in a new choke cable, think I might have run all summer with the choke partially closed, because it was all jammed up.
fixed a broken lever on the heater, and put in a working heater switch. (this was easier said than done!) pulled the kickpanel vents, and vaccumed out the air box, a critter had taken up residence there years ago I guess, full of pine cones and pine needles. replaced the pionts, cap , rotor, and condenser. the cap and rotor were so corroded I am not sure how it even ran. this was all on my 65 dd
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
10-06-2010, 04:58 PM | #1894 |
Who Me?
nothing major, new peep mirrors.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
10-06-2010, 05:28 PM | #1895 |
Got a call from the powdercoater telling me my rallye wheels are ready. I am glad that I'm getting closer to taking off the current ones. Now I can start working on new tire sizes. The manager at the local Tire Max says to bring my truck in and he will mount tires and put them on the truck until I find the size that gives me the stance I want. That is sweet. come to find out he has a 63 shortbed and a bagged and body dropped 46.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
10-06-2010, 08:23 PM | #1896 |
i got my horn working after 3 years and i think my altenator working as well , I was told the guy that helped me redo my truck wired it wrong, the guy owns 4-5-6 chevy truck
10-06-2010, 08:35 PM | #1897 |
Finally got the frame and all the suspension pieces to the sandblaster. Will pick everything up tomorrow.
10-06-2010, 08:57 PM | #1898 |
Got my firewall filled and ready for body filler, next is the drip rail. Previous body work left much to be desired, a portion of rail on pass side back corner is all bondo.
66 c20 with 1/2 ton 73-87 front and rear suspension 2-1/2" drop spindles, air-bags, c-notch rear frame 463 Pontiac, SRP Pistons, Eagle Crank and Rods Mega-Squirt Fuel Injection |
10-07-2010, 12:26 AM | #1899 |
just found where the same 4-5-6 chevy truck put my wiper linkage together wrong, i might get wipers now after 3 years of not having them
10-07-2010, 08:17 AM | #1900 |
I took the day off to work on my truck. I ended up building a table with wheels so I can place the cab a little higher. Without a lift it was tough when your by yourself. But I did it and now Im home again with 2 torn discs I should have known better.
