Old 09-30-2010, 05:53 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Show me your sparkplug wire routing/looms!!
Post how you routed your plug wires, Zip ties? fancy looms lets see em!
(trying to get ideas for myself, centerbolt heads, ram horns)
John
1999 Toyota Tacoma 4x4
Old 09-30-2010, 06:14 PM   #2
big_al_71
big_al_71's Avatar
Re: Show me your sparkplug wire routing/looms!!
here are a couple of picts of mine..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-30-2010, 06:19 PM   #3
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Dang Big Al !! ! That is one clean looking engine bay!
oldblue1968chevy - I think what you are going to find out with your Ramhorn exhaust manifolds that you will be very limited on how you can route your spark plug wires.
Good luck.
There are some very creative folks here and someone may be able to share some pictures of what they have come up with.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 09-30-2010, 07:23 PM   #4
Newtz67
Newtz67's Avatar
A couple of mine. I haven't taken the time to organize at the dizzy yet, but I do like the looms.
Newtz67 is offline   Reply With Quote
Old 09-30-2010, 07:52 PM   #5
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Here is a picture of how I had mine routed for a long time:
I have since gone to a factory-style set up of the wire routing. I used '75 vette wires to get them the right length, though you'll have 1 wire too short if you use all the 67-70 factory looms. If you've got a throttle cable instead of a rod, and use the 71-72 stuff, I bet it will come out perfect.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 09-30-2010, 08:09 PM   #6
TheSeeker
Kind of off topic, but I'd like to know the color blue you have on your truck its awsome! Above poster that is. I just zip tie them because its still a wip and when I get the crate motor in there ill run them factory style.
TheSeeker is offline   Reply With Quote
Old 09-30-2010, 08:24 PM   #7
cparman
sharp as a marble
I ran mine on my truck and Blazer like a 75-80 Corvette. The front two on both side run down, and come up thru the motor mounts. Clean and almost unnoticed.
cparman is offline   Reply With Quote
Old 09-30-2010, 08:28 PM   #8
oldgold70c10
Who's got steelies?
Thanks! Its Rustoleum Sail Blue
My Truck Page
My Youtube Channel
Old 10-01-2010, 09:44 PM   #9
OhioDan
OhioDan's Avatar
Here's how I ran mine, with 75 Vette wires for HEI. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 10-01-2010, 11:45 PM   #10
oldblue1968chevy
Im upgrading to cable throttle anyways...
So vette wires are ok on a mild 350? (see sig)?
cable throttle, 71 72 facotry looms, vette cables 1975
John
Old 10-02-2010, 12:15 AM   #11
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
okay
prostreetC-10 is offline   Reply With Quote
Old 10-02-2010, 04:10 AM   #12
hotrod100
hotrod100's Avatar
Here's what I've got. Not sure it will work with the ram horns though.
My build thread.
hotrod100 is offline   Reply With Quote
Old 01-14-2011, 03:38 AM   #13
CEE1NG_RED
okay
Where did you guys get your looms from and what brand???
CEE1NG_RED is offline   Reply With Quote
Old 11-04-2016, 01:45 PM   #14
Brandon G
Hello, I have a question and hopefully someone will help. I am really digging those looms that run beside the valve covers but will the typical "over the valve cover" plug wire be long enough to run in the looms? Thanks for any and all help.
Brandon G is offline   Reply With Quote
Old 11-04-2016, 04:22 PM   #15
WarMonger
WarMonger's Avatar
went with ceramic plugs for the heat.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 11-04-2016, 05:01 PM   #16
BossHogg69
motor exploder
BossHogg69's Avatar
Short answer is no. Almost positive you'd have to use the longer 'under the exhaust manifold/header' type to get the length needed, or just buy the wire in bulk and crimp your own. The DUI LiveWires I got that are over the manifold are way to short to go into a loom along the valvecovers. On the LiveWires, I used zip ties, because the wires have a protective sleeve over them that makes them too fat for regular wire separators.
I've tried the 90* boot Pertronix Flamethrower wires too, and they seemed like they might be long enough, but it would be really close.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-04-2016, 06:53 PM   #17
Z10
Z10's Avatar
My 72 GMC 350 ZZ4.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 11-04-2016, 07:32 PM   #18
69chevy lwb
69chevy lwb's Avatar
Here's my setup I used to have them hidden under the manifolds but I burnt some wires and it was impossible to work on so this was the solution
69chevy lwb is offline   Reply With Quote
Old 11-04-2016, 08:21 PM   #19
70STOVEBOLT
70STOVEBOLT's Avatar
okay
I like these, can you provide some info on them? My HEI wires are very long and the stock looms don't do a good job of containing them in an orderly fashion.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
