#376 |
Happy to be here
![]() Join Date: Mar 2000
Re: Project: Recycle
Nice design work Scot.
#377 |
I'm just glad to be here!
Looks Good. I wish I could work on mine...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#378 |
Well... One step foward, 2 steps back. I worked on the front shock brackets Friday after work & Sun afternoon, but ran into issues.
Because each of the brackets is hand cut & trimmed independently, there were subtle variations on each. Those variations were causing problems w/alignment or positioning when trying to determine the optimum placement. I could tweak their position, but then when I placed the top covers on them, the covers were not consistent from side to side & looked like butt (not very square & didn't 'flow' well). I was going to try & have my GF's company laser cut some consistent brackets based on my template but they're busy & I didn't want to be a wrench in the works. Instead, I'm going to use some of the RideTech 'universal' weld-on units & I'll tweak from there. They will be a more consistent starting point so I'll end up w/a better finished result. So.... Sunday evening I played around w/my vent window frames. I wound up grinding the 2 rivets off the pivot bracket which will allow installation of the window frame seal. I used small beveled seat machine screws in place of rivets for re-assembly (just verifying they'll do the job). I still want to blast the vent window frames & get them in black epoxy before re-assembling everything. After that, I started making a reinforcement plate for the gauge lens I used in the modifed cluster. The OE lexan/plastic gauge lens was a bit flimsy w/all the holes poked in it. When installed in the housing, it was 'ok', but I felt it could be improved upon (cheaply). I used some steel (0.060 I think) & made a backing plate for the lens. I'll panel bond the 2 together & it should work well (seems more solid just flexing them when not installed). A little more weight, but not so much it will be an issue.
#379 |
Its been 2 weeks, anything new? Are you still trying to make the Goodguys show at TMS Oct 1-3?
#380 | |
While I'd love to drive this truck into the FtWorth event, I know what it takes to get one together & it's highly unlikely. I'll still be @ the show, sans the 64. I did finish the gauge cluster. It's very solid now so the steel 'backing plate' was a good decision.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-14-2010 at 12:24 AM. |
#381 |
I got a couple minutes of shop time & verified the Ride Tech universal shock mounts will work w/a little tweaking for my application. I'll move forward on them as soon as I finish some necessary attention toward the 74.
They're doing major construction in my area & the service road into my subdivision is fubar BAD. Well, navigating through the work zone as carefully as possible yielded a solid THUNK (as in you stopped moving THUNK)..... The result? Two broken manifolds & 2 tweaked OE a-arms. I gotta get the exhaust corrected. The a-arms are drivable but look pretty ugly.
#382 |
that sucks i myself ruined a 4 day old low profile tire and a rim on a pothole once and the one responsible for maintaining that road paid the costs for replacing them ..... this was in europe
i think you can get the construction company for the road or the city lyable for the damage as they didnt closed the road or made an alternative for that road to youre company , might be hard to prove the road responsible for the damage unless you make pictures . as long as you stay reasonable in youre expences they shouldnt give you too hard a time
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#383 |
Well that sucks. I know what you're sayin though ,that construction going on over in your neck of the woods is pretty brutal.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#384 |
Well.... I ordered 1ea pass/driver manifolds for the 74 & got 2 pass units. Since that was definitely the worse of the two, I swapped it out & I'm back in business. The driver side isn't leaking for now but it definitely is cracked.
I'll be working on shock mounts this weekend (Sat).
#385 |
they can be welded with a special weldingrod , i heared sumting of a vibrating table where you mount it on during welding and let it cool inside sand to keep the moleculair structure close to cast iron and prevent stresscracks
#386 |
I would just swap to headers before that.... just didn't want to go that route @ this time. Patch it & return my focus to the 64!
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-17-2010 at 08:54 AM. |
#387 |
I got some time in today to work on the front shock mounts. I spent about half of that time running back & forth between local auto-part joints, Home Depot, & my house. Frustrating to say the least but I pushed on....
The shocks are C10 spec'd Bilsteins, 15.5" extended length w/5" of travel. I set them @ 13.5" length @ 6.5" bag height which = my ride height. This should allow 3" compression w/o fear of bottoming out yet still allow the bag to 'air-out' if desired. I cut off the dbl shear shock brackets I had previously welded on the Ride tech lower a-arms (I was concerned the upper/lower shock eye orientation @ opposing 90° angles would cause a binding condition). I welded some 'new' shock tabs on the side/top of the a-arms (just like how they sell them now). After some intial measurements, I trimmed the universal Ride Tech upper mounts to yield the correct distance between the upper & lower mounts while clearing the upper a-arm shaft hardware & the frame. In these pics, I haven't welded the upper mount yet because I'm still working on the driver side. I want to ensure both sides are the same (placement, angle, & appearance) before final welding of the upper portion. I still need to do the fit & finish on the driver side upper mount & then I can weld both sides up. I also picked up some vent window setting tape @ the swap meet yesterday to start reassembling the vent windows & got my Hush Mat 'kit' for the cab. I think I nailed my target dimensions for the shock length looking @ the last pic ![]()
#388 |
Tot Roddin'
Nice work SCOTI!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#389 |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#390 |
The new lower mount looks much better. Good work.
#391 |
Happy to be here
Progress is good bro. Glad to see you got this obstacle resolved.
#392 |
Nice work
#393 |
Welding on the front shock towers is complete....
#394 |
Under Construction
Nice work!... Nice shop setup.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#395 |
It the maint shop @ my job. Nice stuff; but even after 22+yrs of employment, I have to semi-covertly work on my 'goverment projects' which usually means deep nights.
#396 |
Nice work on those shock mounts. I know what you mean about those "government jobs".
It was good meeting you today. Posted via Mobile Device
#397 |
thats clasified information
#398 |
Funny, but true. I can give my friends/family a tour of the plant where I work. You can see everything except the main area where I work..... it's pass-key access only (even for internal employees).
The funny part is I'm nobody..... Just an average maunfacturing employee.
#399 |
More progress but no pics yet.
I set-up my extra swb frame w/a DM main crossmember on my trailer. It's just the main rails, front DM x-member, & T/A x-member sitting on some 2x4's & spare wheels. This allowed me to put the sbc/700r4 in place for determining the tranny x-member needs. I have several x-members for consideration & decided to use an ECE x-member as I feel it will offer better torsional rigidity vs. a tubular unit (it bolts to the top & bottom of each frame rail vs. just the sides). Because the DM relocates the drivetrain slightly, I'll need to cut the mount 'flange' off the x-member, flip the x-member 180°, & re-weld the mount flange. This offered the best alignment of the 'puzzle pieces' & should work well. I'm actually going to place the mount flange w/a little fudge factor in the dimensions & use a shim for dialing in the level (to set the carb flange @ 0°). I ran out of time tonight so I'll try & get @ it earlier tomorrow. I had to wrap the drivetrain in towels, cardboard, & plastic to keep moisture @ a minimum until I can get it back in the garage tomorrow. I'm crossing my fingers we won't see any sudden 'scattered showers' before then....
#400 |
Scoti
For the front shock brackets you got from RideTech, how thick is the material they used? After this past weekend, I think that I might shoot for getting mine rolling/driving for the spring show. Thanks,
