10-03-2010, 09:01 PM | #1 |
Robert Olson Transport
what did you get done 10/3/10 edition
Ive been busy doing things in the house and i had to make several appearances on behalf of the family at funerals this week so nothing truck related
How about you all?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-03-2010, 09:03 PM | #2 |
Re: what did you get done 10/3/10 edition
Retuned the truck, worked on the interior some, flushed the radiator. That was about it.
10-03-2010, 09:05 PM | #3 |
Location: Where I come from, it's cornbread and chicken...
I worked Saturday and slept in today...so I didn't get much done besides the fact I covered a door panel for everyone to see and order...
10-03-2010, 09:05 PM | #4 |
got the rest of the roll cage pieces and window net, and finally bolted the rear back in with fresh 456 richmond gears, a moser spool and moser c-clip elims.
10-03-2010, 09:12 PM | #5 |
i didn't do anything besides break my cruise control switch on the column, broke my perfect factory steering wheel and chipped away at my freshly painted fenders! great times in the garage this weekend!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
10-03-2010, 09:16 PM | #6 |
Ordered all the parts for my 80 to (73-79) front end swap, which should get here by Tuesday. In the meantime I started removing all the 80 front end parts, layed down a fresh layer of paint on the core support, and leveled out and polished up the front bumper. Man, I can't wait for the new parts to come in!
10-03-2010, 09:20 PM | #7 | |
looking not so good ... |
10-03-2010, 09:21 PM | #8 |
Slugish
Don't blame you that you cant wait .Will be sweeeet. Good luck .
10-03-2010, 09:28 PM | #9 |
Formerly- 1972SuperCheyenne
Celebrated the Birthday. (it's not actually till the 5th. Will be 32 this year) Wound up with lots of help to order the wheels, etc. Cant wait. Also drilled and tapped the water pump for the nipple for the bleed hose. Thats about it.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
10-03-2010, 09:31 PM | #10 |
Stitch- door panel looks great man- I am sure I will deal with you in the future, once I aquire a Dually.
I don't have a square dually as of yet to work on....but I did work on the car my future square will be pulling! BEFORE- AFTER- 9" install pics. Narrowed 3"/side, backbraced, spooled, 4.11's, 35 spline axles, strange nodular center section, etc... Last edited by Leedogg; 10-03-2010 at 09:37 PM. |
10-03-2010, 09:33 PM | #11 | |
It followed me home?
i want!!!
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
10-03-2010, 09:38 PM | #12 |
Thanks. I've been really eyeing your work and I'm very, very impressed. I can't wait to move on to my interior so I can hit you up. I'd love to get my dash and door panels all hooked up.
Thanks. I'll post up my updates in my build thread...Project "FATBOY" |
10-03-2010, 09:43 PM | #13 |
Adam- they aren't cheap- but they say it should handle anything I plan to throw at it. Got rid of the crappy factory 10 bolt years ago, for a 12 bolt. 2 trips to the track and the 12 bolt became a whine monster...so now I am to this.
10-03-2010, 09:47 PM | #14 |
spent all damn day trying to get one measly little wiper arm off to no avail. not even one of those ghetto removal tools worked!
10-03-2010, 10:01 PM | #15 |
I went back to the boneyard to get more interior parts from the truck I got my dark brown sun visors from. The truck was gone. I looked over at the crushing area, and there was a long bed with a decent driver door on it. So I snagged the door. The vent window hinge was busted. And there was some rust on the bottom. But the door skin itself was pretty straight except the edge at the rear of the door that is supposed to create the gap with the back of the cab was bent in a bit. Hopefully not hard to fix. Hopefully I got my tail light fuse blowing issue worked out. Lots and lots of bare wire by the back bumper. Installed the new door, used the vent window from the old door. Checked out the run-ability issue with the engine today. Did a compression check that revealed #1 cylinder only has 45 pounds compression, while all others have over 100. FML. Looks like I need a new engine. No more effort to spend on a 1969 307 block. I'm done with it. I'll run it while I get the old Cummins going again. Then it'll go back in the garage till I can afford a new engine. Crap crap crap.
10-03-2010, 10:17 PM | #16 |
6.0 powered square
finally got my harbor freight sand blaster to work I was able to get nearly 70% of the frame blasted, I'll be able to finish it tomorrow if I get off work before 6, and went to good guys today saw kens 77, wow its a nice truck
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
10-03-2010, 10:39 PM | #17 |
I finally finished up my roll pan install. Didnt turn out too bad for having zero welding experience. Next its on to the bed stakes.
10-03-2010, 11:30 PM | #18 |
^^^ looks sweet ^^^
10-03-2010, 11:47 PM | #19 |
acrophobia- Nice work on the roll pan...stak pockets are cake after that. BTW- Same mickey T's I have on my T/A.LOL
10-04-2010, 12:17 AM | #20 |
Turned 40 on Saturday . Started the day early , cut some firewood for the winter, went out to eat , etc. Mounted some 275/60/17 tires on some TT2's I have to see how they looked on the longbed but never actually bolted them on . today was a lazy day.
frank
Born and proudly residing in a Red State ! |
10-04-2010, 12:24 AM | #21 |
MOTORHEAD!
Gutted the interior in my 82. Broke the head off the seat belt mounting bolt. grrrrrrrrrr!!! Can't wait to order carpet and new seat cover, as well as STICHES dash pad!
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
10-04-2010, 12:40 AM | #22 | |
Thanks nbpro! |
10-04-2010, 05:51 AM | #23 |
Old Heap Driver
I spent most of the weekend in Va Beach at the "Wild Wheels Weekend" indoor and outdoor show. The Heap was inside and won a "Top Pick" award, my S-10 was outside and grabbed a "Sponsor's Choice" award. Sunday's outside show was canceled due to rain.
Had a Blast!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. Last edited by S10Fan; 10-04-2010 at 05:59 AM. |
10-04-2010, 05:57 AM | #24 |
Old Heap Driver
I thought you guys might like this one. '75 Long Bed, Pro-Charger, and has been featured in Truckin. Super nice guy, the truck has been "finished" for a few years, still looks brand new in and out.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
10-04-2010, 08:21 AM | #25 |
Removed the AIR tubes and broken bolts from the exhaust manifolds which was a PITA. I had to drill out one and enlarge to 7/16' then had to make a special 7/16 to 3/8* stud.
Finished (almost) stripping the 87 GMC frame. |
