Old 10-04-2010, 08:42 AM   #26
cochino12
It followed me home?
cochino12's Avatar
Re: what did you get done 10/3/10 edition
got my dually back from the paint shop and lowered it.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-04-2010, 08:54 AM   #27
Leedogg
I love it- i know you originally wanted the blue on top- But am digging it the way it is!
Leedogg is offline   Reply With Quote
Old 10-04-2010, 09:35 AM   #28
camshaftgsxr
camshaftgsxr's Avatar
went to look at an 81 for my girlfriend.
camshaftgsxr is offline   Reply With Quote
Old 10-04-2010, 12:34 PM   #29
nikwho
nikwho's Avatar
I got a TON done on my '83! My '59 was neglected once again. I put a new set of Heddman Headers on. Dropped it off at the muffler shop and had the new headers tied into a 2.5" dual exhaust with a couple of flowmasters. I replaced the old q-jet with a new edlebrock carb. New MSD cap, rotor and plug wires. New flex-a-lite fan. And a fresh oil change. Pretty productive. I have a 350 getting ready to go to the shop to get vatted, bored .040 over and reassembled with fresh bearings, pistons, oil pump etc. It will be about 10:1 comp. with the new pistons and the new patriot performance heads. Need to pick the cam grind and when its all done it will replace the old 305 thats in there now.
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 10-04-2010, 01:33 PM   #30
boatpuller
boatpuller's Avatar
saturday was beautiful sunshine.so,i got the 79 out and drove it down to lowe's.on the way home while i waited at a stop sign.i saw a group of teeners on bmx'x eyeballin the truck.i didn't wanna dissapoint the little bugger's.and much to their delight i pulled off a big nasty burnout when leaving that stop sign.......i also winterized our new to us fifth wheel....."the big wheel"...probably a skosh over the weight limit for the 79 c10.don't you think? ...so,i have to use the dodge cummins.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 10-04-2010, 01:47 PM   #31
bigblock73
yeller
bigblock73's Avatar
I dug a giant hole, cut a hole in the house foundation, and put in an egress window. It will be our daughters new room when finished.
Did go junkyarding Friday, got a bunch of stuff I needed for the 73, and even got a 78 tach cluster I will be listing to help offset my out of pocket expenses.
bigblock73 is offline   Reply With Quote
Old 10-04-2010, 01:58 PM   #32
Stitch
Location: Where I come from, it's cornbread and chicken...
Nice find Jeff
Stitch is offline   Reply With Quote
Old 10-04-2010, 01:59 PM   #33
bigblock73
yeller
bigblock73's Avatar
wheres my dash?
Old 10-04-2010, 02:17 PM   #34
Stitch
I'm getting the vinyl book tomorrow so I can match up the color.
Old 10-04-2010, 02:39 PM   #35
D13
D13's Avatar
Finished levelling the first floor section of the pole barn and moving in in the crushed/ broken concrete. Finish graded the two ouside walls with the pavers complete. moved the fine sand from the driveway to the barn area, broke up and hauled away the concrete that the truck washed onto my driveway gravel pile. Put in bolts to hold down the CDR and intake muffler on the diesel. Gave the new 77 the eveil eye but didn't actually work on it yet. Did i mention the disc brake Caprice rear end and the pile of 455 Buick parts that needed moving? Then went to the inlaw's 60+ anniversary dinner, letting the Advil comfort my back. Ain't so young anymore.....
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-04-2010, 03:34 PM   #36
Cue-Ball
Cue-Ball's Avatar
On Friday evening I put in new plugs and checked my plug wires. Couldn't find my tube of dielectric grease, so I'll have to go back and grease everything tonight after work. I also pulled both door panels, greased the roll channels, and sprayed the window channels with silicone spray. Both of my windows were very difficult to put up before (had to use two hands!). I'm surprised I didn't break my window crank. But now both of them are much smoother and can be cranked pretty easily. Also pulled the front wheels and checked the brake pads. They still look like new, so I'm good for a while.
On Saturday I spent the whole day at the shop sanding my '70 Camaro. Need to get the whole car sanded with 180 grit, then go over it again several more times to get ready for paint.
Cue-Ball is offline   Reply With Quote
Old 10-04-2010, 03:49 PM   #37
3r!c84
Badass
3r!c84's Avatar
work then sanded and painted all the brackets and pullys off of the motor. tourqed the heads down. put in new fuel pump.adjusted roller rockers.
oh and a big box from summit came in.... (:
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-04-2010, 04:09 PM   #38
rfmaster
rfmaster's Avatar
Saturday I went to a local JY - nothing square body related.
Sunday morning (no more heat) replaced both caliper hoses and bleed brakes on my '75. This turned out to be easier than I thought - flared crowfoot wrench (3/8") on short extension made a quick job of unscrewing hardline from the hose.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 10-04-2010, 05:15 PM   #39
69subaru360
69subaru360's Avatar
Went to EZ pull and got a trailer hitch. Putnam class 5 10,000/14,000 in great shape for $15. Can't beat that. I mounted it with all new grade 8 hardware. The crossbar hangs a little below the bumper, which I don't like, but for $15 I cant really complain. It even had a bracket to relocate the spare tire hanger and the spare fits with the hitch. It's way more hitch than I need, but peace of mind is good. I would have been pushing it with a 5 or 6000 lb hitch.
I found out my reese brake controller is a perfect fit where the ashtray goes.
Just need to get a 7 round plug and it's all ready to tow.
I have a bunch of stuff on order that should show up this week. Sherman repro radiator, belts, hose and tune up parts.
69subaru360 is offline   Reply With Quote
Old 10-04-2010, 05:37 PM   #40
tucsonjwt
Installed long fuel hose to replace the short vent hoses on the dual tanks. Ran the hoses to the back of the truck and mounted on the cross brace above the spare tire, then reinstalled the vent caps. Also tightened leaking fuel inlet nut. Gas smell all gone now - hope gas mileage improves a little on the BB.
tucsonjwt is offline   Reply With Quote
Old 10-04-2010, 10:12 PM   #41
N2TRUX
Happy to be here
N2TRUX's Avatar
I spent last week thrashing to get the Ride Tech E3 system installed in my 77. I ran in to sensor issues that I just could not get resolved in time. I had to set the system to read bag pressure and focus on detailing the truck. I spent the last two nights before leaving wrapping up the install, and detailing the truck.
Thursday night I hit the road for Ft Worth to be in the Ride Tech booth at the Goodguys show. I made it there at 3:00 am and got a few hours sleep before set up on Friday morning. Despite the long hours and lots of moments of frustration, the effort was worth it.
Here it sits in all its glory at the Ride Tech display.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-04-2010, 10:21 PM   #42
lolife99
67-72 parts collector,…
lolife99's Avatar
Beatutiful, Ken,... just beautiful!
Keith
Convert to disc brakes.
Old 10-04-2010, 10:25 PM   #43
79gmcclassic
79gmcclassic's Avatar
gorgeus truck!
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 10-04-2010, 10:30 PM   #44
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I tried to modify the '09 silverado middle console seat and didnt go to well. I tried to modify it so it would recline more... yeah, didnt go well.. I think a nut and bolt will be the winning ticke to go back together... if not its 100 bucks for the pivot arm
Mounted the BMW rear view mirror. Its got a led at the bottom for an alarm, 2 buttons for misc stuff (hidden). Waiting to find the same mirror with homelink (why i did this in the first place). Its got 3 programmable buttons for garage doors ... once i fit the modified mirror glass in there, I'll update with pictures.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 10-05-2010, 05:29 AM   #45
S10Fan
Old Heap Driver
beatutiful, ken,... Just beautiful!
x2
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 10-05-2010, 12:05 PM   #46
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks guys. Your compliments are always appreciated.
Articles-
"Refining Sierra"
Old 10-05-2010, 08:58 PM   #47
S10Fan
Old Heap Driver
Ken.......Does that air system have a minimum psi requirement for height settings?
Bryan
Old 10-05-2010, 09:07 PM   #48
78 Chevyrado
Painted the outer stripe on my headlight bezels black. Repainted some of the trim screws that had started to rust.
78 Chevyrado is offline   Reply With Quote
