I am torqueing down my oil pan bolts to the recomended 80 Inch lbs and I have snapped 3 of them so far. Anyone else have this happen?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Resident Curmudgeon
![]() Join Date: Dec 1999
Not to insult anybody but is your torque wrench set to inch pounds or foot pounds? 80 inch pounds is approx 7 foot pounds (12 x 7 = 84)
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Yeah, i have one for foot pounds and one for inch pounds, It's all set right
if i was you i'd get some new ss bolts and recheck you're torque wench settings because they're barley beyond finger tight at 80inch'pounds, at that setting you shouldn't snap even plastic bolts
Fabricate till you "puke"
Possibly the bolts bottomed out, before they tightened?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
even if they bottom out you will still reach torque you just wont have any clamp load. and I agree 80 inch pounds is not enough to break anything...
Good luck
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
I figured it out!! operator error. I was using a buddys torque wrench that doesn't CLICK when it get to torque spec, this one just gives a bit. So I was tightening the sh@t out of them. What a dumbass!!!!
What if?
DOH!!!!!!!!
ouch i been there done that ![]()
2002 red extended cab Silverado 2002 Wheatland yellow Suburban |
you make a good case why not to lend or borrow tools
Robert Olson Transport
![]() Join Date: Oct 2002
lol hey i been there done that youll only curse three or four dozen times while youre drilling them out have fun!!!
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
I had to heli coil one of them, the others came out fine. But i went back to check my timing chain cover because it was the same torque spec and 5 of them snapped off
Got it all fixed up
Weapons Of Construction
OUCH! Sorry to hear about that Dubie...
A buddy of mine rebuilt an engine and used a cheap-@ss tiawanese torque wrench to torque the bearing caps. Galled several rod and main bearings because they were overtightened. That was an expensive lesson for him to learn.
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
