Old 10-04-2010, 08:12 PM   #1
Sixxer
Sixxer's Avatar
Confused... Inline 6 ?'s
Ok I have a massive exhaust leak between my intake and exhaust... do they actually mate together and why? There is black soot all over the area around where they come together and I can visually see the gasket missing. Here is the replacement gasket I found.
http://www.oreillyauto.com/site/c/de...3929&ppt=C0026
The problem is I can only find 1 bolt, the middle one on the outside. There aren't anymore! I found holes 2 holes in the intake but there is nothing except a bump in the exhaust manifold on the front and back one... It this my nightmare... Someone broke them off in there?
Sixxer is offline   Reply With Quote
Old 10-04-2010, 08:36 PM   #2
292farmer
292farmer's Avatar
Re: Confused... Inline 6 ?'s
either broke off, or were forgotten to be put back in or they maybe wormed their way out.
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 10-04-2010, 09:13 PM   #3
Sixxer
Sixxer's Avatar
Jeezus..... I poked around , they are defiantly broken off in there. Any ideas on what to do?
Old 10-04-2010, 09:17 PM   #4
I have never been able to do it other than pulling both the intake and exhaust off, then replace all the gaskets, then both them back on again. Not real hard. To me the hardest part was always the doughnut flange for the exhaust pipe. It always gave me fits. Everything else was super smooth. I have not even had to readjust the carb either.
Old 10-04-2010, 09:22 PM   #5
Sixxer
Sixxer's Avatar
If I told you I just replaced the doughnut for the exhaust pipe and after several revs under hood I watched the gasket blow out... Yeah..
Old 10-04-2010, 09:47 PM   #6
Yep....been there done that!
Old 10-04-2010, 10:28 PM   #7
Sixxer
Sixxer's Avatar
What I really wanna know is why on earth there is a gasket between the intake and exhaust...
Old 10-04-2010, 10:57 PM   #8
bubba327
HOW long until spring??
bubba327's Avatar
Pull the intake and exhaust manifolds and clean things up. There is a heat riser passage that allows exhaust gas to circulate up around the intake around the carb base if the bi-metal heat riser is working. this carbons up and needs cleaned out. the heat riser also rusts up and will stick open , closed or somewhere in the middle.
There should be three bolts connecting the exhaust manifold to the intake manifold., Sounds like you may have some missing or broken hardware.
The intake manifold can be changed to a clifford or offenhauser intake, but they should have hot water jacket cast into the bottom especially if headers are also installed . The inline six can be cold blooded with out the two manifolds working together, But the reverse can also happen. the fuel can boil out of the carb in extreme heat of summer.
P.S> the gasket is there to prevent the exhaust leak that you have now
good luck
The gasket shown in your first post is the correct one. But if you get the intake/Exhaust block gasket kit , It comes with a new base gasket and a exhaust doughnut plus a solid gasket for LPG applications(between the two manifolds)
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 10-11-2010, 02:34 PM   #9
Sixxer
Sixxer's Avatar
good luck
Thank you! I understand now. I'm not interested in spending the bucks for a header and intake swap but I would like to invest in studs instead of bolts for the intake and exhaust manifold. Anybody know where to get a set of these? I did a search on here and found nothing but I remember reading a post about how they make everything a lot easier to install. Plus since I already have some broken hardware I'm a little iffy re-using the bolts. I would also like to remove the front and rear dowel pins and install bolts or preferably studs. Does anybody make an intake/exhaust stud kit for these engines??
Old 10-11-2010, 06:29 PM   #10
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Just have to buy a length of threaded rod and cut to lengths required.
Old 10-12-2010, 05:50 AM   #11
Vernski
Hey sixxer try this web site they have lots of inline stuff they will have the exhaust bolt kits....Vernski
http://prostores1.carrierzone.com/se...com/StoreFront
Vernski is offline   Reply With Quote
Old 10-12-2010, 01:24 PM   #12
enick72
enick72's Avatar
I had some exhaust manifold studs for 2.5/4.0 jeeps in my tool box left over so I used them, they have locking nuts to keeps them from backing out. These worked good for my application with headers I just installed. if you are using stock manifold you will need a couple long studs or just use the 2 long bolts.
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 10-12-2010, 03:48 PM   #13
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I don't have a big leak there but it's starting.So I went to the local JY and got another exhuast mani since I had replaced the donut a couple years ago and knew the studs to the exhuast pipe were "IFFY".The one I got has broken stud(or did have) I drilled them out and picked up a tap but haven't redone it yet.I picked the studs up in the "HELP" section of the LPS.I wanted to be able to tear it down and put it back together instead of having it down while I fixed/found stuff.neither of them has a working heat riser,so I need to adress that also.I had cleaned up and done a spray bomb cleanup on the engine bay and wanted to paint the mani with VHT while I was doing this.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-12-2010, 06:00 PM   #14
292farmer
292farmer's Avatar
has anyone ordered from them? they have alot of stuff! i want it all
Old 10-12-2010, 08:48 PM   #15
Sixxer
Sixxer's Avatar
I did this afternoon... their exhaust stud kit is on its way!
Now my next issue is should I drill and tap the exhaust manifold holes? The intake to exhaust bolts on the inside were broken off from someones previous repair attemp... or should I try and track down another manifold? Ideas?
Old 10-12-2010, 09:49 PM   #16
raycow
I like the idea of drilling and tapping so you can use studs instead of bolts. If you assemble the manifold with brass nuts instead of steel you shouldn't have any problem the next time you need to need to take it apart. This used to be standard practice on old engines, but you don't see it any more.
Ray
raycow is offline   Reply With Quote
Old 10-12-2010, 09:53 PM   #17
292farmer
292farmer's Avatar
let me know the how fast the shipping is and quality!
Old 10-14-2010, 02:33 AM   #18
Vernski
I ordered the Clifford intake with a adapter plate for a Edelbrock carb , I like it and the quality is good and shipping fare but I'm only a few states away. They have allot of nice cool stuff for in-lines....Vernski
PS They make adapter plates for all carbs!
Old 10-15-2010, 02:29 PM   #19
292farmer
292farmer's Avatar
what blower will work on their blower intake? looks like a 142/144 weiand blower mount.
Old 10-15-2010, 04:11 PM   #20
Sixxer
Sixxer's Avatar
I don't know about that, but I ordered the studs monday and they shipped out tuesday... Thats impressive imo....
Old 10-15-2010, 04:23 PM   #21
292farmer
292farmer's Avatar
sweet, seems like they have some good feedback. i'm really liking that blower intake, but will definitely need to save up! i actually found a vid with this intake! its so sexy
