Old 10-05-2010, 09:50 AM   #1
nikwho
nikwho's Avatar
Rear axle
I didn't want to hijack on another thread so I started a new one. So, my rear axle is a 14B Full floater, right? identified by the eight bolts on the rear hub?
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 10-05-2010, 09:54 AM   #2
nikwho
nikwho's Avatar
Re: Rear axle
Raycow, you told me "The FF has a 10.5" ring gear and no C-clips. The FF also has a straddle-mounted pinion like a Ford 9" or the GM-built 3/4 and 1 ton rears used 72 and earlier."
I just wanted to confirm what axle I have under my truck. That kind of thing is good to know. Thanks Ray
'68 GMC - BBC/TH400
Old 10-05-2010, 10:06 AM   #3
Burt4x4
Burt4x4's Avatar
Re: Rear axle
Yup that is a 14FF the 14SF would not have that hub sticking out of your wheel.
Here is mine..looks the same to me.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-05-2010, 01:32 PM   #4
raycow
Re: Rear axle
Well its a FF for sure, but not necessarily a 14 bolt without seeing a pic of the center section. 72-earlier could have had a Dana 60 or H052.
Ray
raycow is offline   Reply With Quote
Old 10-05-2010, 01:38 PM   #5
nikwho
nikwho's Avatar
Re: Rear axle
oh, yeah. Its def. a 14 bolt. I was just not sure of the differences between a ff and a sf. I do appreciate the help!
'68 GMC - BBC/TH400
Old 10-05-2010, 05:09 PM   #6
82swampthing
82swampthing's Avatar
Re: Rear axle
full floaters have hubs on the end of the axels and the axels bolt in, The semi floater has c clip axles that are just that held in with c-clips and there is a 1" difference in the ring gears.
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
