Old 10-05-2010, 07:36 PM   #26
Newtz67
Newtz67's Avatar
Re: layed out 67 swb project M.A.C.
I agree with everyone else, an amazing build man! Thanks for sharing the process with us!
Newtz67 is offline   Reply With Quote
Old 10-05-2010, 08:56 PM   #27
E_Markward
Nice Build. Other than the bags and the Z, are you running drop spindles to lower the front
E_Markward is offline   Reply With Quote
Old 10-05-2010, 10:04 PM   #28
ebfabman
Very nice work, but I didn't see any link to limit lateral movement of the rear axel. Did I miss it?
ebfabman is offline   Reply With Quote
Old 10-05-2010, 10:17 PM   #29
Dan in Pasadena
Dan in Pasadena's Avatar
Did I miss it? What is the name of your green color?
Dan in Pasadena is offline   Reply With Quote
Old 10-05-2010, 10:24 PM   #30
jlaird
jlaird's Avatar
LOVE IT! This pretty much is what is in my head for my truck.
jlaird is offline   Reply With Quote
Old 10-05-2010, 11:01 PM   #31
thelonerife
thelonerife's Avatar
Very Nice build! congrats!
thelonerife is offline   Reply With Quote
Old 10-05-2010, 11:42 PM   #32
McClinton527
McClinton527's Avatar
ya I am running drop spindles i bought on ebay... Although with small diameter wheel and tire setup and the large z and bags, (with the removal of the bump stops), they may not be necessary... i think the thing would still lay out with stock spindles in my case.. if i was to do it again I wouldnt z it as much and run spindles for sure.
McClinton527 is offline   Reply With Quote
Old 10-05-2010, 11:46 PM   #33
McClinton527
With the giant width tabs and bushings oppose to hiem joints on my traingulated upper link there is now lateral movement possible. In addition each of the lower links have equivalent bushing setups both on the front x member and on the rear end...
Old 10-05-2010, 11:49 PM   #34
McClinton527
I dont actually have a name.. I was painting some cell tower pieces for a company that were disguised as lamp posts and they brought us a color chip. Our local paint supplier did a prophet scan on the chip and custom created the color. I really liked it so I had more made and used it on both my motorcycle and truck... Id probably call it an olive green or something, and the off white color is simply called "buff"
Old 10-06-2010, 12:25 PM   #35
ebfabman
What are you doing for driveshaft clearance? Is the cab floor modified for a driveshaft?
Old 10-06-2010, 12:47 PM   #36
sandnuriz
sandnuriz's Avatar
Very nice work every part of the truck wow great job!!!!!!!!!
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 10-06-2010, 12:48 PM   #37
68laydout
Junior Member
68laydout's Avatar
Nice work man! Chevelle is sick too.
68laydout is offline   Reply With Quote
Old 10-06-2010, 01:25 PM   #38
McClinton527
I wish I had a better picture.. I will try and take one soon. It is a two piece driveline with a slip joint and a carrier underneath the cab towards the back but pretty much hidden if you look from the bed opening. No cab modification necessary. the carrier is a stock style out of a parts truck that has been attached to a custom tube cross member that bolts between the frame rails. I hope this helps, let me know if you have anymore questions.
Old 10-06-2010, 01:29 PM   #39
LEEVON
Moderator
LEEVON's Avatar
You need to change your user name to "McBaddestasstruckever" or something modest like "McTruckoftheyear".
Seriously cool build, you have real talent.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 10-06-2010, 01:35 PM   #40
gixxerpymp
How long did this build take you?
gixxerpymp is offline   Reply With Quote
Old 10-06-2010, 01:52 PM   #41
McClinton527
Started the project beginning of January.. worked on it every extra minute I had between then and August when it made its maiden voyage.. since then its been worked on here and there. keep in mind I have a more than full time position running a body shop. But it kept me out of trouble for the most part these last several months. Also drained both me and my bank account lol. totally worth it with all these great comments though!
Old 10-06-2010, 04:33 PM   #42
-sean-
Thumbs up Re: layed out 67 swb project M.A.C.
Can you post up some specs for the wheels and tires you are running? They look perfect for this style of build.
-sean- is offline   Reply With Quote
Old 10-06-2010, 07:18 PM   #43
McClinton527
195/70-15 stock steel wheels i believe theyre like 5 or 6" wide...
Old 10-06-2010, 10:52 PM   #44
butternut1972
butternut1972's Avatar
AWESOME BUILD! This is one of the best looking trucks i have seen. Great work.
butternut1972 is offline   Reply With Quote
Old 10-06-2010, 10:59 PM   #45
kvn1011
Kvn1011
kvn1011's Avatar
that is nice!! Really really nice!! do you have a pic of your rear airtank set up??
or even video of your canti set up!! i have a york compressor also, hopefully i can do something close to what you have done!! awesome truck bro!!
kvn1011 is offline   Reply With Quote
Old 10-06-2010, 11:19 PM   #46
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Sweet looking truck!!
Hope you get up to the Portland Vancouver area so we can get a close up view. Very nice work..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-07-2010, 12:22 AM   #47
jwalk
What was I thinking?
jwalk's Avatar
SICK!!!!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 10-07-2010, 12:54 AM   #48
McClinton527
The back half of my frame is air tight and is the air tank... I have a fitting welded in the inside of the frame rail behind the rear cross member i think some of the pictures in my thread show it
Old 10-07-2010, 02:23 AM   #49
JesseH13
AMBITION
JesseH13's Avatar
bro i love this truck honestly its my fav one on this forum i look up to this truck and wat u did to it!!! im going with that same look on my truck too the all original slammed look!
1979 Nova-daily-R.I.P
1976 c10 "daily"-
1968 c10 -project
CROOKED68 (PROJECT)
JesseH13 is offline   Reply With Quote
Old 10-07-2010, 11:10 PM   #50
McClinton527
Old school original look is where it's at!
