Old 06-11-2003, 06:38 PM   #1
Chad
Chad's Avatar
rebuilding Transfer Case
I am finally getting started on my 70 Blazer. Just had a question or two about the drivetrain. I will be rebuilding the engine and tranny soon and would like to know if you can rebuild the transfer case? And where is the best place to get these parts (for the transfer case)
Next question. I have a closed knuckle front axel in it now. I also have an open knuckle out of a 72 Blazer in the shop. What all in involved in swapping the two? Is it worth the effort? Will the turning radius improve?
If I do the axel swap I will swap the rear end too. The 72 Blazer had a 4 inch lift. So, I will have to get BIGGER tires (Yee-Haw). I think I can get the wife to go for that LOL.
Chad
Chad
69 Short Fleetside
72 2wd Blazer
70 4x4 Blazer
67 Chevy(big window) Just a cab for now
64 Chevelle SS (2dr Ht)
Chad is offline   Reply With Quote
Old 06-11-2003, 07:43 PM   #2
CEDJUNIOR
I know that you can rebuild a T-case, parts are probably available the same places you'd go for the tranny parts. I'm not too sure about the other stuff.
GM RPO Codes
'95 K1500 4x4 Ext Cab
5.7 TBI
NV4500 Tranny, 14 Bolt swapped in, locker, 3.73's
CEDJUNIOR is offline   Reply With Quote
Old 06-11-2003, 10:24 PM   #3
Chad
Chad's Avatar
Thanks for the info CEDJUNIOR. I'll have to check with the people I'm getting the tranny rebuild kit from. Anybody else know anymore 'bout this or the axels questions?
Chad
69 Short Fleetside
72 2wd Blazer
70 4x4 Blazer
Old 06-12-2003, 05:07 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Try this: http://www.bulldogs-house.com/Projects/np205/
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-12-2003, 10:16 AM   #5
Chad
Chad's Avatar
Thanks for that JIMs70GMC. I will try to find all the parts to do that. Anybody know on the axels?
Chad
69 Short Fleetside
72 2wd Blazer
70 4x4 Blazer
Old 06-12-2003, 11:32 AM   #6
Blazer1970
Blazer1970's Avatar
The axles are a direct bolt-in swap. You will get a better turning radius with the open knuckle axle, as well as disc brakes. Well worth the effort to swap 'em out.
Blazer1970 is offline   Reply With Quote
Old 06-12-2003, 05:04 PM   #7
jwhitfield
I was able to purchase a video on how to rebuild an NP205 transfercase. If your interested, I'll look to see where I got it and send ya the info....JW
jwhitfield is offline   Reply With Quote
Old 06-12-2003, 09:16 PM   #8
Chad
Chad's Avatar
Thanks for the info Blazer1970. Also, jwhitfield send me the info.
Chad
69 Short Fleetside
72 2wd Blazer
70 4x4 Blazer
Old 06-12-2003, 11:13 PM   #9
1969 GMC
1969 GMC's Avatar
also, open knuckle axles have larger ujoints and are thus stronger...i'd like to do a similar swap
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-13-2003, 03:42 PM   #10
jwhitfield
I'll dig it out tonight and send it off sometime this weekend....
Old 06-20-2003, 03:30 PM   #11
jwhitfield
Sorry for the time delay....distractions at home, memory going. Anyway here's the info for those who are interested in purchasing videos on rebuilding NP205s and other stuff....
http://www.technicalvideos.com
Call Today! 1-888-785-2604
