Old 10-06-2010, 04:30 PM   #1
dccarpenter
Should I tow blazer with C30 and towbar?
Just found a good deal on a '75 Blazer but it needs to be towed to me due to the brakes being out.
I have a C30 one ton dually with a heavy duty bumper, it's rated for 4,000 pounds tow(no hitch on the truck at the moment), I can buy a towbar at Autozone tonight for 70 bucks to tow it home with. If I stick to non-highways think it'll work out ok? I'll be driving like a grandma maybe 30-35 max speed. I know the weight will be a touch over(truck weighs 4500 according to Google, no back seat/spare though so that drops it 4300lbs probably) what the bumper's rated for but seeing if anybody thinks it'll be a major issue.
Also, since it's 4x4 do I need to disconnect both driveshafts or will just the back be ok?
dccarpenter is offline   Reply With Quote
Old 10-06-2010, 05:36 PM   #2
swampfox
swampfox's Avatar
Re: Should I tow blazer with C30 and towbar?
You might check the price to rent a trailer instead of buying the tow bar.I pull a 71 charger with a 440 with my 69 half ton. the main problem was the on dirt roads the car would not follow at times and it made the trip more exciting than I cared for. Another problem was the front of the car was heavier than the back of the truck. the trailer would be safer.
69 gmc 4x4 lwb 327 4sd not running
swampfox is offline   Reply With Quote
Old 10-06-2010, 05:39 PM   #3
Jonboy
Slots go on anything!
Not sure about using the towbar vs. a trailer, but you can put the transfer case in neutral, and tow it like that if you are going to flat tow it.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 10-06-2010, 06:11 PM   #4
dccarpenter
I considered the trailer and would go that route as they are cheap to rent, however I don't have a hitch and I was worried the added weight of the trailer + the blazer would far exceed the 4,000 pound suggested limit for my bumper.
My truck itself is heavy , being a one ton and a dually, and with a good hitch I wouldn't hesitate to pull 2 trucks at once. Just trying to get this 1 blazer home without buying a towbar and a hitch...(plus taking the time to install the hitch in the dark in my apartment lot parking lot tonight) or renting a trailer and buying a hitch.
I've pretty much decided to grab the towbar and give it a shot, worst case scenario is it doesn't feel good and I pull into the closest Autozone and buy a hitch, install it in the lot, then hook the truck backup to the hitch via the towbar.
Old 10-06-2010, 06:12 PM   #5
83burban
Unless you plan on putting a tow hitch on it, you cannot safely pull a trailer and a car.
Flat towing should be fine as long as you are driving slowly and carefully. I always bunjee corded the steering wheel to center so that when the car was tracking through turns the wheels could return to center and not lock to one side.
83burban is offline   Reply With Quote
