Old 10-07-2010, 10:29 PM   #1
truknut
truknut's Avatar
Brake problems
I have a cousin that has a 72 GMC truck. He's having problems with his brakes. We bled the brakes and got a good pedal, but when we cranked it, the pedal goes to the floor. What causes this?
1990 Chevy Silverado (My DD)
1978 Chevy Bonanza LWB (My LWB to SWB 1 day project)
2015 Hyundai Sonata (Wife's DD)
truknut is offline   Reply With Quote
Old 10-07-2010, 11:06 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Brake problems
Get a new master cylinder. The mc piston seal goes bad or splits allowing fluid to go past it and that lets the pedal go down.
They're not that expensive and should solve your problem. If it's been replaced recently, take it back and get a replacement. Be aware that new ones can also fail so keep the receipts.
68gmsee is offline   Reply With Quote
Old 10-07-2010, 11:33 PM   #3
llowlife
Re: Brake problems
Rebleed you brakes if it still doesn't help see above post. Make sure you "bench bleed " the MC as it saves alot of agony.
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
