Old 10-09-2010, 09:17 PM   #1
Martin64
Martin64's Avatar
Has anyone successfully done a 2wd to 4wd conversion?
Has anyone converted a 4-5-6 from 2wd to 4wd? I read through the build threads and couldn't find one with final results. I'm not dead set on doing this but am considering it really hard using my frame and 73-87 axles/springs/etc to go under it. Nothing crazy, just a longbed, streetable 4wd truck.
Thoughts? Warnings? Ideas?
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 10-10-2010, 10:38 AM   #2
'63GENIII
'63GENIII's Avatar
Re: Has anyone successfully done a 2wd to 4wd conversion?
I did it with a 77 crew cab dually about 10 years ago. I always say that I'd never do it again and just get an original one. Now I have a '62 that I bought sight unseen that had been swapped on to a suburban frame. I don't like the job that the P.O. did so I bought an original '63 K15 that I am much happier with.
I guess if you have the time, space, intestinal fortitude and understanding wife that I had back then, I would say go for it. I do remember being really proud that I had built that truck myself and it was a pretty awesome truck.
If you have the donor truck, take lots of pictures of how things attach along with lots of measurements. They will come in handy when you do the swap. I also remember steam cleaning all the parts and my truck really well which made the job way cleaner. Have good sharp drill bits for driling brackets and the frame, as well as a good grinder with plenty of metal blades for cutting off rivets. Keep a bunch of grade 8 hardware 1/2" and 9/16" for all the suspension and crossmember attachments on hand too.
Lastly if you do this conversion, take lots of pictures so the next guy will have something to help him out and so guys like me won't even think of doing it again when the itch strikes! Best of luck whichever way you go. You're in the right place to figure it out.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
