Old 10-10-2010, 12:19 PM   #1
brans72
Transmission crossmember ?
I am doing a little searching with no luck so far so figured I would ask. Will a transmission crossmember from a 83 1500 fit in a 67 C10? I will be using a 700r4 transmission. Thanks Brandon
brans72 is offline   Reply With Quote
Old 10-10-2010, 02:38 PM   #2
cdowns
cdowns's Avatar
Re: Transmission crossmember ?
i believe those frames are not the same wdth so crossmembers dont interchange
Old 10-10-2010, 02:58 PM   #3
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
cpp makes a tubular one that will do the job for cheap and allow for exhaust to be run over the crossmember if you are going low with it, under $100 with a poly mount
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 10-10-2010, 03:55 PM   #4
brans72
On there website does not state will work with 700r4. I believe it would but figured I would ask.
Old 10-10-2010, 04:04 PM   #5
tantrumpipeline
I would call to make sure, ask for Jeff, he's great to deal with and gives a site discount, the 700r4 is a 2 bolt mount I believe isn't it? my catologue says all gm 2bolt mount transmissions, I have a th350 myself, they come powdercoated silver and very nice
20 Duramax tow pig
52 short project
Old 10-11-2010, 09:55 PM   #6
brans72
Can you not run exhaust over the stock transmission crossmember?
Old 10-11-2010, 11:11 PM   #7
tantrumpipeline
not to my knowledge due to the width where it attatches to the frame, check with the site vendors, most of them give a site discount, CPP is 10% and I had a great dealing with jeff, but they all have good products and depending on mild to wild, you'll find what you need and knowledgable help.
20 Duramax tow pig
52 short project
