Old 10-11-2010, 11:47 PM   #1
cb1965
cb1965's Avatar
what 350 trans?
hey all
i have a '65 lwb chevy. 350 crate engine with 2 speed powerglide and was
gathering info on what is needed to upgrade to a 350. trans from what year
vehicles will work and if i need a different drive shaft. all info is appreciated.
thanks
cb1965 is offline   Reply With Quote
Old 10-12-2010, 04:23 AM   #2
raycow
Re: what 350 trans?
Get a "short" TH350 (Approximately 27"-28" from bellhousing face to rear seal) and your stock driveshaft and crossmember will work as-is). The transmission can come out of a car - it doesn't have to be from a truck.
You will still need to cobble the shift linkage, kickdown cable, and cooling lines.
Ray
raycow is offline   Reply With Quote
Old 10-12-2010, 04:36 PM   #3
cb1965
cb1965's Avatar
Re: what 350 trans?
is there a year range? or any short 350 will work?
Old 10-12-2010, 05:24 PM   #4
raycow
Re: what 350 trans?
AFAIK, they didn't change significantly over the years. The only one you might want to avoid is the 350C which uses a lockup converter and has a bad rep. It can be identified by an electrical connector on the case. The regular 350 has no connector.
Naturally, you want to be sure yours has a Chevy bolt pattern, not BOP. In other words, you want the front of the bellhousing to look like the one on your powerglide.
Ray
