Old 10-12-2010, 03:13 PM   #1
bfay17
Young Gun
bfay17's Avatar
front springs
I wanna build my front packs up a little and was wondering if i could ure the rear overload spring from the rear on the bottom of the front spring pack? Will this make the front to stiff or cause stuff to wear out faster or would it be alright? Im gonna be taking the rear packs out anyway to put new ones on so i just thought if i could use the overloads to lift the front a little i would.
Thanks,
Brandon
bfay17 is offline   Reply With Quote
Old 10-12-2010, 05:20 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: front springs
Not sure but I think the front & rear are different widths...
When my fronts were sagging, I ran AAL for awhile, and they squeaked. I finally got 2" Softrides.... costs more, but much better.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-12-2010, 05:29 PM   #3
bfay17
Young Gun
bfay17's Avatar
Re: front springs
If they are the same width would they be alright? i got aal's in currently but im looking for just a little more lift height. Im gonna get 6 inch springs eventually but for now i just wanna do it safely and relatively cheap.
Old 10-12-2010, 07:06 PM   #4
turp mcspray
turp mcspray's Avatar
Re: front springs
When I lifted my blazer, I cut the overloads, and used them like a small lift block. It bolted to the spring pack with the rest of the springs. I figured overloads on a blazer just didn't make any sense, and I was planning to rock crawl with it, and didn't need them hampering my flex. If they are the same width as your front springs, that is what I would do. Mine were about 3/4" thick, so it won't get you much.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-13-2010, 10:43 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: front springs
I don't see why not...
- Mike -
RIP El Jay
Old 10-13-2010, 05:35 PM   #6
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: front springs
if you use the overload full length I believe it will be like running a solid bar and if you wheel it at all it there will be no or very little flex
powerdriver 1958 is offline   Reply With Quote
Old 10-13-2010, 06:38 PM   #7
bfay17
Young Gun
bfay17's Avatar
Re: front springs
Alright thanks for the replies i think i may cut it down to like 6 inches from each side of the whole and call it good. I was afraid the full length would be like riding on a tractor with no flex at all.
Brandon
Old 10-14-2010, 10:58 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: front springs
Grind a nice radius on the cut spring so it dosent rub a groove into the spring above it.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-14-2010, 12:03 PM   #9
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: front springs
If you take a look at my build page you can see an extreme front leaf pack setup... I'm building my truck to plow snow with a heavy 8' boss blade. I might have to take a few leaves out once it's all together but you'll get the idea. Just need a longer center bolt and longer Ubolts and it'll go together!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 10-15-2010, 01:28 PM   #10
bfay17
Young Gun
bfay17's Avatar
Re: front springs
Those look like some really stiff packs but yes i get the idea now. Time to get some new springs to tear apart
Thanks,
Brandon Fay
Old 10-20-2010, 08:44 PM   #11
motomaster99
motomaster99's Avatar
Re: front springs
be very careful when you build up the stock leaf springs. Remember that these springs are most likely original which means they've taken 40 years worth of bumps.
I found this out the hard way when I replaced everything but the main spring in the front with 3" dump truck springs. Managed to provide 4" of extremely still lift. Which makes the truck awful to drive and even worse off road.
I ended up breaking my driver side main spring-which is extremely dangerous because at that point nothing is holding the axle straight. Currently my axle is chained in position on the driver side with a chain from the u-bolt to the bumper bracket.
I just got my 6" e-z ride springs yesterday, and will be installing them this weekend. These new springs use new technology than the originals and provide an awesome ride and performance on and off road. I firmly believe now when it comes to your suspension your better off doing it the right way even if it costs you.
but, it can be done the cheap way! just be careful!
motomaster99 is offline   Reply With Quote
Old 10-20-2010, 08:50 PM   #12
motomaster99
Re: front springs
oh yea and they do sell what is called a zero-rate block, which is basically a 1" lift block that is attached to the spring pack using the center bolt. They are legal; even for the front, because it is essentially a sawed-off leaf pack.Off road design sells them (offroaddesign.com) they're 40 big ones.
Old 10-20-2010, 08:54 PM   #13
motomaster99
Re: front springs
The front is 3" at the eyes, but tapers to 2.5" at the center bolt. The rears are 2.5 all the way.
It is easier to use 2.5" springs in the front under your main because if you use 3" spring you have to grind a groove in them to allow the U-bolts to fit, which can ruin the integrity of the spring.
Old 10-20-2010, 09:57 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: front springs
^^ That sounds right.... I had forgotten exactly what the difference was.
And in case I wasn't clear, what I meant was I got new Skyjacker Softride front springs, in 2" lift (or 2 1/2"... not sure just which they are called). They are 2 1/2" wide along their full length.
- Mike -
RIP El Jay
Old 10-20-2010, 10:48 PM   #15
bfay17
Young Gun
bfay17's Avatar
Re: front springs
ALright thanks guys i added 2 leafs to my front packs along with a 1 inch zero rate but im going to just buy new 6 inch springs when this spring comes around. I just need it driveable this winter if i need it.
Brandon
Old 10-22-2010, 11:29 PM   #16
motomaster99
Re: front springs
Brandon
exact same process I went through. Trust me with those stiff leafs you'll be very excited to put in your 6" ez-rides. I just put mine in tonight.
Old 11-10-2010, 11:50 PM   #17
bfay17
Young Gun
bfay17's Avatar
Re: front springs
Well heres how she sits its a 70 3/4 ton. Its got a 454/sm465/np205 dana 44 front and eaton rear. Its on about 4 inches of lift im guessing but it may be a little more. The tires are 36x12.5 on slots. I Have to finish the cab and redo the floor and a few other small things but for right now im very happy with it. What do you guys think?
Old 11-11-2010, 12:19 AM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: front springs
Lookin good! I don't think you're more than 4" though, especially in front. How does it ride? Is there any rubbing, like on the front lip of the front fenders when the tires are turned?
- Mike -
RIP El Jay
Old 11-11-2010, 01:26 AM   #19
vk_chevy
vk_chevy's Avatar
Re: front springs
it looks good
so, how did you end up setting up your suspension? just the softrides?
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 11-11-2010, 01:34 AM   #20
swamp rat
swamp rat's Avatar
Re: front springs
Lookin good!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-11-2010, 01:40 AM   #21
bfay17
Young Gun
bfay17's Avatar
Re: front springs
The front doesnt rub unless im fully flexed and turning. I ended up using a 2 inch add a leaf and a leaf from the rear packs plus a 1 inch zero rate. It rides like a lumber wagon thats on steroids but its a truck and it pulls like a mother . Its far from perfect and i still have a slight front end shake at about 30-35 mph but im sure the tires arent helping that.
