10-13-2010, 09:15 PM | #1 |
Seat belts
I've got a 97 burban that just going to be a mud truck, so I wont be needing the seatbelts anymore. I've been thinking about putting them in my '68. I would like to at least get one of the lap belts for the middle so I can haul three people safely in my truck, and also if possible get the three point seatbelts, atleast the driver's side anyway, anybody done this? How would I attach the lap belt,? could I use the existing bolts on the floor of the truck or would I need new bolts so I don't exceed some kinda rating? and how bout the three point? no idea where to start there. thanks yall!
'68 C10 LWB 6.2NA/NP833 3.73's |
10-14-2010, 06:05 PM | #2 |
Re: Seat belts
I do suggest going with the three point set up, on a 72 cab theirs a upper support for a 3 point belt maybe you could cut one out and weild it in you're cab; maybe you could rob one from a later year model doner vehicle. On you're cab cut a "window" in the sheet metal where the third point connection will be you may have to engineer a brace to weild a threaded nut to bolt to, if you could'nt rob one from a doner vehicle. I suggest opeaning the doner up first and get an idea what it will intell to properly install and reinforce a thread/mount that would support a upper seat belt mount. I have a 71 cab that already had the upper hitch point in it from the factory I guess they were getting ready for the 72 year models that had the factory three point belts.
10-14-2010, 08:19 PM | #3 |
Re: Seat belts
I just put 3-points into my 68, using Wesco belts.
http://wescoperformance.stores.yahoo.net/seatbelts.html Juliano's also has similar belts and instructions. I took my lapbelt and used the existing holes/bolts to lace it down. I've got two males for free waiting for homes. http://67-72chevytrucks.com/vboard/s...d.php?t=424529 MJH |
10-15-2010, 12:33 AM | #4 |
Big Red - Now its a SWB!
Re: Seat belts
My 68 has upper mounting points. I've heard that s10 belts bolt right in, I was looking at a 90's suburban the other day and it looks like they would bolt up too. Let us know how it turns out!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
10-15-2010, 02:15 AM | #5 |
Re: Seat belts
Most of the parts houses carry a 3pt belt system for our trucks, as far as the center belt i would have just bolted it to the existing bolts and never second guessed it, but i guess you could reinforce the floor if concerned.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-15-2010, 12:30 PM | #6 | |
Re: Seat belts
MJH |
10-15-2010, 12:35 PM | #7 |
Re: Seat belts
10-15-2010, 12:51 PM | #8 |
Re: Seat belts
ixnay, Does your truck have the gas tank in the cab? I'm just curious about having enough room for the retractor on the drivers side. Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
10-16-2010, 01:19 AM | #9 |
Re: Seat belts
in interested in this too
10-05-2011, 12:24 AM | #10 | |
Re: Seat belts
I've attached photos. You might consider getting longer belts if that is an option. These fit me, but the females barely come through the seat from the floor. And for heftier people, the males don't work as well. I used the old belt for the center, so I can take my daughters with me when I go bouncing around. MJH Last edited by ixnay; 10-05-2011 at 12:40 AM. |
