Old 10-12-2010, 12:35 PM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Super leaky windshield
Hi guys, its raining in my Blazer! What would you guys recommend to seal it up? I am thinking the glazing compound would be good, but its so gooey. Any other ideas out there? I've heard not to use silicone. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-12-2010, 12:48 PM   #2
Lee H
Lee H's Avatar
Re: Super leaky windshield
Find the nearest windshield installer and have them remove and replace it
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-12-2010, 01:43 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Are you sure that it is the windshield? Where is the leak? You know it isn't uncommon for the windshield to get the blame when it is the sheet metal.
Member Nr. 2770
Old 10-12-2010, 05:08 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I'd start with a new gasket.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 10-12-2010, 08:47 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Pull the windshield, inspect windshild frame it might be rusted out. After cleaning and repair, install winshield with new gasket. If you try to seal it up with silicone or whatever you may end up trapping mosture in there and cause it to rust faster.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-12-2010, 10:06 PM   #6
red71cheyenne
Back in the sticks
This is an all newly refurbished windshield frame on the Blazer that I just restored. Its definitely leaking in around the windshield as you can see the water puddling in the gasket!! This is the windshield I had so much trouble getting installed as it wouldn't fit and had to do some grinding on the glass and the frame to get it in there. It has a new gasket, new glass and like I said, the frame is basically new.
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-12-2010, 10:15 PM   #7
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Use self-leveling silicone. Basically it remains liquid long enough to flow to where the leak is, then it solidifies.
Zoomin is offline   Reply With Quote
Old 10-12-2010, 10:26 PM   #8
red71cheyenne
Back in the sticks
This is on the glass side right? I'm trying to keep all the silicone off the metal as I've heard it'll cause problems with the paint later on. I was going to use glazing compound on the metal side.
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-12-2010, 10:33 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
What about the urethane that glass installers use on the late models? I've also seen glass men use some kind of caulking that is injected between the glass and the gasket.
Member Nr. 2770
Old 10-12-2010, 10:45 PM   #10
red71cheyenne
Back in the sticks
May have to stop at Safelite and ask them if they know what you are talking about. Was kind of thinking I might do that anyway as they couldn't get it in there to start with. I'd love to have it not leak at all. It just rains too much here.
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-12-2010, 10:54 PM   #11
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I pull the rubber gasket back and it goes between the gasket and the glass, but some probably gets on the metal that's not seen.
Old 10-13-2010, 06:08 AM   #12
Zeke
Active Member
You shouldn't have had to grind the glass to fit as it is in front of the frame when installed. One tip I got from the service manual is to carefully lay the glass on the frame and 'adjust' frame to fit contour of the windshield. It also says to apply sealer on the bottom and upper corners.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 10-13-2010, 11:01 PM   #13
red71cheyenne
Back in the sticks
When I split the frame in half to sandblast and repair rust, I think I shrunk the whole thing a bit when I put it back together. The opening wasn't as big as it originally was and thats why the glass guys ground it down a little. They eventually gave up trying to get it in and I also had to do some opening of the frame itself. Thats all probably part of why it is leaking.
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-14-2010, 04:19 AM   #14
Zeke
Active Member
I would try some flowable silicone windshield and glass sealer or even black rtv. Since the rubber is new it is still flexable, use a dull putty knife and lift the edge of the rubber squirt some in and work your way around. Use a razor blade to clean off any that squeezed out after it cures. Might be better to remove the windshield and dry and clean the channel put sealer all around the glass and reinstall.
If your Blazer is already painted silicone won't be a problem.
1969 C10 350 3spd
Old 10-14-2010, 01:35 PM   #15
red71cheyenne
Back in the sticks
Thanks, I had thought about pulling it, but worried the silicone would ruin the paint. If its already painted it won't hurt it?
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-14-2010, 05:44 PM   #16
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
RTV....if it is NOT the automotive variety, will react with the sheet metal. If you don't believe me, take a look at this picture. This is what non-automotive RTV will do.....all because a previous owner was trying to stop a leak. This is before I pulled it out of the trough....which is what you see. When I pulled it out, it was amazing that the front of the firewall stayed attached to the rest of the cowl.
Member Nr. 2770
Old 10-14-2010, 05:52 PM   #17
red71cheyenne
Back in the sticks
Thanks Ray. I'm going to consult the windshield guys at Safelite to see what they can do for me. I know they also guarantee their work, so might be a good way to go.
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-14-2010, 08:12 PM   #18
R.L.
R.L.'s Avatar
This thread is useful, I just had new glass installed front and back; the new gaskets don't seal like the old one's did. Theirs places that you could slide a piece of paper between the metal and rubber I know water will get in there. Automotive RTV,self sealing if possable.
R.L. is offline   Reply With Quote
Old 10-14-2010, 09:49 PM   #19
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Here's the stuff I was talking about....
Old 10-14-2010, 10:03 PM   #20
red71cheyenne
Back in the sticks
Thanks! I'll try and find the stuff and go from there.
2011 K1500 Suburban
2014 K1500 Pickup
Old 10-15-2010, 05:19 AM   #21
Zeke
Active Member
Ray's right, the wrong stuff will have a very strong smell. I always play it safe when I buy black RTV and make sure it meets GM specs.
1969 C10 350 3spd
Old 10-15-2010, 11:56 PM   #22
69 longhorn
I worked in glass for 10yrs,.....long enough to cut the windsheild on my old chop top I you have a leak, I would not mess with silicone....glue it down with ureathane....& dont look back crazy AL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
