Old 10-16-2010, 10:53 AM   #1
norske
"Custom" Wood Bed.
Got an idea from all the wood beds here and came up with this. Box is 6' X 8' foot (LWB). Used two sheets of 4X8 plywood, cut a foot off of each one, coated with 4 coats of McCloskey's weather sealer, covered seams with lattice strips. Bolted to the frame with carriage bolts with BIG washers. Whadda ya think? Does it look ok?
norske is offline   Reply With Quote
Old 10-16-2010, 10:55 AM   #2
norske
Re: "Custom" Wood Bed.
The finished product.
Old 10-16-2010, 01:08 PM   #3
Shane
Shane's Avatar
looks good ... and if you like it then that's all that matters.
Shane is offline   Reply With Quote
Old 10-16-2010, 01:38 PM   #4
gssmith89
Very resourceful, I like it! Plus were not all able to shell out the clams for a whole wood bed kit right now. Good work!
gssmith89 is offline   Reply With Quote
Old 10-16-2010, 03:13 PM   #5
tommyd241
tommyd241's Avatar
Looks nice. Good job!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 10-16-2010, 03:30 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
Looks good! And if you ever intend to use it as a truck you won't have to worry about dinging a high dollar wood bed kit or the metal strips...
Old 10-16-2010, 03:45 PM   #7
tonypaul
tonypaul's Avatar
Looks good! Might been kinda cool if you made some fake lines with a darker colored stain. Kinda were it looks like planks... Im just thinking out loud...
tonypaul is offline   Reply With Quote
Old 10-18-2010, 08:33 AM   #8
ges55
BLACK SATIN
ges55's Avatar
I think it looks good. I put plywood over my old wood bed & found some black sealer to match the truck color.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 10-18-2010, 11:45 AM   #9
Stock72c10
classic=of recognized value
Stock72c10's Avatar
Are there holes someplace for water to drain out (rain/washing, etc.)?
Looks nice.
Stock72c10 is offline   Reply With Quote
Old 10-18-2010, 12:12 PM   #10
big_al_71
big_al_71's Avatar
Looks great!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-18-2010, 12:28 PM   #11
RUSHNBOBO
Looks great!!!
You can also add divider strips using the low buck method.
Use thin strips of stainless about 2 inches wide and lay out evenly spaced on top of the plywood drill 1/8 holes spaced max of 2 inches and use either long aluminum rivets or stainless button or counter sunk screws.
I used the rivet method on mine "diamond plate aluminum" and they pull down and hold surprisingly well in dry plywood...haven't lifted at all in 6 years but I don't haul anything either.
If you do use it for work just throw some scrap ply on top of a blanket and away you go
>>>>>>>>>>>>>>>>>>>>Rushnbobo
RUSHNBOBO is offline   Reply With Quote
