Old 10-04-2010, 09:35 PM   #1
vanceman
Jeep Springs
I have been reading on here where a lot of people are using Jeep springs to get a 4" + drop. If you used them did you have to modify the spring retainers because mine bottom out before they get tight on the spring, and exactly how much drop did you get? I got a set given to me and I am trying to figure out if I want to try to use them or just buy some 4" drop springs. Any thoughts and tips would be greatly appreciated.
vanceman is offline   Reply With Quote
Old 10-05-2010, 08:22 PM   #2
vanceman
Re: Jeep Springs
So I take it that no one is running Jeep springs.
Old 10-17-2010, 02:00 PM   #3
sv10001975
sv10001975's Avatar
Re: Jeep Springs
i've got a set to, but haven't had time to install them yet
sv10001975 is offline   Reply With Quote
Old 10-17-2010, 07:19 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Jeep Springs
I understand its more for drag racing, more stored energy
Old 10-17-2010, 07:34 PM   #5
qksilver
Re: Jeep Springs
I have a set and am using them. On a jeep, so not much help but if you need pix on how they are mounted i could take some when i am out at my shop on Thursday. It's a 79 cherokee if that helps.
Pm me
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 10-17-2010, 10:35 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Jeep Springs
Im running them
late 90's TJ rears
You cant haul much with em, they do bottom out with the retainers, I havent worked that out yet..You can make your own shock relocators, and adj panhard bar also, post back if ya interested..
I may swap mine back out for stock, caues i use my truck as a truck too much to justify the awesome stance..
John
1999 Toyota Tacoma 4x4
Old 10-17-2010, 11:07 PM   #7
raycow
Re: Jeep Springs
Is this for front or rear?
Ray
raycow is offline   Reply With Quote
Old 10-18-2010, 07:39 AM   #8
Indian113
Indian113's Avatar
Re: Jeep Springs
I'm using the TJ springs on my 64 in the rear,I only got a 3" drop but I like it. Haven't tried hauling anything in it as I don't use it as a DD. The spring retainers bolted right up No problem.
Indian113 is offline   Reply With Quote
Old 10-19-2010, 09:49 AM   #9
M5-
Re: Jeep Springs
Basically the same here. I just flatened the spring retainers with a hammer which basically just took the dome out of them and they hold the springs fine. They ride really nice but I don't think they do too much for the performance too soft. I ended up with about 2 3/4" drop on a short step, you might get more on a long fleet or heavier truck.
M5
M5- is offline   Reply With Quote
Old 10-19-2010, 07:33 PM   #10
oldblue1968chevy
Re: Jeep Springs
^Good idea about the hammer, will do mine next time they are off
John
