Old 10-18-2010, 01:26 AM   #1
coggonobrien
need help running hot wire for hei
hi guys converted over to hei on my 355 in my 69 blazer. just need help running the new hot wire to it. where do i take it in the fuse box and what do I need to connect it? pictures would be great.
Thanks,
David
coggonobrien is offline   Reply With Quote
Old 10-18-2010, 05:32 AM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: need help running hot wire for hei
Sorry no pics, but you need to connect the wire to the "unfused ign" terminal of the fuse block. to connect it to the fuseblock you use a crimp on 1/4" female spade terminal then you connect the other end of the wire to the +12V terminal of the HEI with another 1/4" female spade terminal. I recommend using a decent pair of crimpers as the cheap ones give a poor connection that can come loose. Also it wouldn't hurt to an inline fuse since the terminal on the fuseblock is unfused. Good luck and let us know how it turns out
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 10-18-2010, 05:34 AM   #3
coggonobrien
sweet, is the fuse block clearly label for the terminals? sorry i'm being lazy. this ought to be interesting as the truck ran very well when i had the hei hooked up with the original resistance wire.
David
Old 10-18-2010, 05:49 AM   #4
Jacfourteen
Yeah the fuse block says "ign unfused" in white letters so it is easy to spot. It should be a pretty easy job.
Old 10-18-2010, 05:50 AM   #5
coggonobrien
sweet, thankyou sir
