10-18-2010, 03:38 PM | #1 |
OBD II scanner port problem?
The other day, my wife's '04 Suburban "check engine" light came on. Over the weekend, I went to my local AutoZone to have the computer scanned to find out what the problem is. The guy plug the scanner in and it was not responsive. The scanner would not even come on. AutoZone guy thought that it was a computer problem or a bad OBD II port connector problem.
Has anyone else had this problem...or know what the problem is? Thanks
’67 C10 Custom LWB Fleetside, 283 bored to 301, 3 on the tree ’04 Suburban, 5.3L Vortec Last edited by nitrojunkie383; 10-26-2010 at 06:38 AM. |
10-18-2010, 03:50 PM | #2 |
Charlie Daniels w/ a Tq Wrench
Re: OBD II scanner port problem?
Does your cig lighter work? I believe they share the same fuse in 03+, scanner won't read unless that fuse is good.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s Last edited by GCncsuHD; 10-18-2010 at 03:50 PM. |
10-18-2010, 03:59 PM | #3 | |
Thanks for the advice.
’67 C10 Custom LWB Fleetside, 283 bored to 301, 3 on the tree ’04 Suburban, 5.3L Vortec |
10-18-2010, 07:48 PM | #4 |
change out teh cigar fuse under the hood the cig ligter and obd2 share the same fuse on just aboute very vechile but the gms are bad about blowing that fuse
10-19-2010, 07:58 AM | #5 | |
Thanks for your help.
’67 C10 Custom LWB Fleetside, 283 bored to 301, 3 on the tree ’04 Suburban, 5.3L Vortec Last edited by nitrojunkie383; 10-19-2010 at 07:59 AM. |
10-19-2010, 12:18 PM | #6 |
so did that fix the problem for you what was the code or was it the fuse going out
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die." Last edited by bumslie75; 10-19-2010 at 12:19 PM. |
10-26-2010, 06:38 AM | #7 |
I have fixed one problem and now know what the other problem is. Changing out the blown 15amp fuse under the hood fixed the cigarette lighter and the OBD port as well. Hooked up a scanner to it, and everything functions like it should.
Now for the check engine light. The scanner code is "P0442". It also said that it was an "emissions leak". So I am guessing that its refering to the "evaporated emissions leak" deal where it could be several things, one of them being the "loose gas cap". I have cleared the code, and checked the gas cap and for now, all is well. Thanks for the help everyone.
10-28-2010, 10:11 PM | #8 | |
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
10-29-2010, 08:18 AM | #9 | |
We haven't been overfilling the tank...it's hard enough to keep a half tank in a suburban! Not to say that the PO didnt overfill it. We have had the burb for almost a year now, so I am learning about the truck as problems arise. So far the light hasn't come back on, but then again, its only been a few days. Do you have the GM part #'s for the solenoid and canister handy? Not a big deal if you don't.
10-29-2010, 09:39 AM | #10 |
pm me your vin number and I will get you the part numbers. no problem. then just order them from gm parts direct... They sell the parts to public for what the dealership gets them for plus shipping. If you have had it a year and never overfilled it. I would just put the updated vent solenoid in it.. I can fax you instructions on installation. Basicly you just run the vents filter along the frame rail to on top the transmission. It keeps the dust out that ruins the solenoid in the first place. But if the code doesnt reset, your good to go! It usually takes a few days and a few warm up cycles.
01-31-2011, 07:53 AM | #11 |
Probably just couldn't get the port to fit well. its a tight fit. And check the cig ltr fuse.
_____________________ cars for sale classic cars for sale |
01-31-2011, 08:14 AM | #12 |
he said the fuse was blown and he replaced it and it works now
02-08-2011, 07:59 AM | #13 |
I don't get why they put the two on one fuse,Look how much people use the cig lighter for power.
