I am looking for a Relay Expert for my AC
I have wired my entire truck and everything is going well. Except I am totally confused about if I need a relay and how to wire it if I do for my AC unit. I have a Southern Air Superfrost unit. By the time you plug in all the pre-wired wires, you have two wires, a red power wire with an in line 20 amp fuse and a black ground wire. All of the switch and thermostat are wired in the switch enclosure. I understand you normally want relays for high power items. Maybe this is not considered high power since it only has a 20 amp fuse, I don't know.
Re: I am looking for a Relay Expert for my AC
take a look at this diagram from vintage air. it tells you how wire a relay in. its how i wired mine.
1950 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=335667 1965 F*rd Stang http://67-72chevytrucks.com/vboard/s...d.php?t=399891 1931 F*rd Model A http://67-72chevytrucks.com/vboard/s...d.php?t=496016 1954 Chevrolet Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=486183 |
| Bookmarks |
| Tags |
| relay |
| Thread Tools | |
| Display Modes | |
