Old 10-18-2010, 08:01 PM   #26
jondancer
Re: Inside Of Glovebox?
ya i would like to see some pics also...
i have looked for a moulded plastic version but cant find one.
jondancer is offline   Reply With Quote
Old 10-18-2010, 10:09 PM   #27
LockDoc
The Older Generation
LockDoc's Avatar
You did some diggin' on this one didn't you...
I know someone on here was making them at one time or they were in the process. Tri-Pro maybe? There are posts on here somewhere about it...
It's in this thread. Starts on page four, post #78. Doesn't look like it ever happened...
http://67-72chevytrucks.com/vboard/s...d.php?t=229223
LockDoc
Leon
Old 10-19-2010, 05:57 AM   #28
67C10BUB
67C10BUB's Avatar
My Old Air kit came with a plastic one. Maybe someone could call them and see if they sell them separately. Just an FYI, the factory glove box light won't work with the Old Air plastic one though.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 10-19-2010, 06:13 AM   #29
thunder71
thunder71's Avatar
i have changed out 2 different trucks & i resin coated both with good results.....just use fiberglass resin with hardener & coat the inside & outside....works very well...
thunder71 is offline   Reply With Quote
Old 10-19-2010, 08:36 AM   #30
larry may
Smile Re: Inside Of Glovebox?
Originally Posted by Longhorn Man View Post
that was common back in the day.
If you make a liner out of sheet metal, you'll want a rubber mat, or even carpet. The junk rattling will drive you NUTS
The junk rattling will drive you NUTS[/QUOTE]
lol "be a short trip on this end........"
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 10-19-2010, 09:12 AM   #31
djmachinist
djmachinist's Avatar
Originally Posted by bowtieboy93 View Post
when I bought my truck, it had a plastic one in it. not sure where uts from though
Mine is also plastic, it came with the "Vintage Air" AC kit. But its quite shallow compared to the original.
Dale
1969 GMC SWB FLEETSIDE
ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR
DALE JONES
MY BUILD THREAD: "69 GMC SHORT FLEET"
http://67-72chevytrucks.com/vboard/s...d.php?t=388447
djmachinist is offline   Reply With Quote
Old 10-19-2010, 02:08 PM   #32
RPBurris
RPBurris's Avatar
I would think if you had an old liner you could use it as a template. Aren't the paperboard ones basically all one piece and then stapled at the top? I have been holding on to my old ratty liner with hopes of making a metal one. Can you just pop the staples, unfold it onto a piece of sheet metal, mark your lines and start bending? That sounds way too easy but maybe that is it.
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
