Blazer top repair
So I have 2 tops for my blazer, the one that is on it is the better of the two but it has some sags in the roof, it is a double wall top, are these repairable,
the second top is pretty flimsy and broken down and has one small section cut out of it (passengers door area by the bed) I might cut it up to dispose of it but I dont know if they are fixable |
needs more $$$
Re: Blazer top repair
subscribed...trying to figure out if sagging is repairable too...
1970 2wd Blazer |
Back in the sticks
Mine didn't have any sags, but I did have to replace the bolt down areas on the bottom edges. Used 2x4's cut down to just fit in there and then some threaded inserts. Seems to be working ok. Not pretty, but functional.
As far as the sagging goes, I would think that you could access it from the inside with a hole saw(real careful like) and then either prop it up with wood strips or even some expandable foam. As long as its on the top side, I don't think you'd have to worry about it sucking up water and damaging it.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty Last edited by red71cheyenne; 10-19-2010 at 09:50 PM. |
