Old 10-19-2010, 08:54 PM   #1
1985LT1_C10
1985LT1_C10's Avatar
700r4 shifting problem
my 700 is stuck in first gear.....tv cable is properly adjusted.....if your governor went south will you still be able to shift out of first gear manually? anyother suggestions before i drop the pan?
Ross K
1985 Silverado LT1
1970 Chevelle SS396
1985LT1_C10 is offline   Reply With Quote
Old 10-19-2010, 09:52 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 700r4 shifting problem
Is this a new tranny? Check the governor gears. After checking try this method. New transmissions sometimes get stuck in first. Accellerate slowly. When is should shift to second, turn off the engine for a few seconds. Coast for just a few seconds. Throw it in neutral and crank it up. Accelerate. It should shift into second. Try a few times. If it fails to shift, you have problems inside the tranny.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-19-2010, 10:16 PM   #3
1985LT1_C10
no its not a new tranny...i installed a B&M transkit dropped it back in and now it wont shift out of first....
Ross K
1985 Silverado LT1
1970 Chevelle SS396
Old 10-20-2010, 01:13 AM   #4
gchemist
gchemist's Avatar
HMMMM, B&M makes a good drill bit in my opinion. You probably have a check ball missing out of place.
Old 10-20-2010, 10:56 PM   #5
1985LT1_C10
tapped on the governor with a hammer ...problem solved!!
Ross K
1985 Silverado LT1
1970 Chevelle SS396
Old 10-21-2010, 12:15 AM   #6
Stitch
Location: Where I come from, it's cornbread and chicken...
where's the governor at? that might be whats wrong with mine...mine seems fine when the engine first starts, but once you let it idle a minute or two and the line pressure builds up, it doesn't want to shift into first or anything unless you pull it all the way down into first...
also, it doesn't want to shift out of first once it's in first...before the line pressure builds up it'll shift all the way into OD if you start the truck and immediately drive it down the highway...
Stitch is offline   Reply With Quote
