Old 06-14-2003, 05:10 AM   #1
ddsmith
Glowing since 1978
ddsmith's Avatar
Power steering gear box adjustment?
Anyone have information on power steering gear box adjustment. My truck has the wandering thing going on. I think the box is not adjusted properly. I was planning on using a dial indicator off of the pitman arm and adjust the box until only a very small amount of steering input causes pitman arm movement. Any other suggestions?
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 06-14-2003, 09:51 AM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You can adjust the steering gear easy enough, but you need to be careful not to over do it. That can ruin a steering gear easily. When I adjust a steering gear I only give the adjusting screw 1/8 of a turn at a time until I take up excess slack. You will need some slack in the gear so you won't want to adjust it all out. Some thing that you should check before you start adjusting you steering gear is your tie rod ends, pitman arm, and the tires. If any of those are bad or your tires are half worn out, that will cause the wandering problems you are experiencing. Also if your truck has the old bias ply tires, those were notorious wanderers.. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
