Old 10-20-2010, 04:36 PM   #1
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Seat belts
Try to take my seat belts buckles apart and get the belts out so I can wash them is their an easy way to get them out with out braking the buckles.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 10-20-2010, 07:35 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Seat belts
Don't try to pry the plastic piece of the buckle. The plastic is old and probably brittle and can break. At least it did on one of mine.
68gmsee is offline   Reply With Quote
Old 10-20-2010, 07:55 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Seat belts
They are more forgiving if you heat them up slowly with a heat gun... .but not too much heat or you will melt them. It also does wonder to rejunvenate color in them. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 10-20-2010, 08:18 PM   #4
Thealien
Thealien's Avatar
Re: Seat belts
They can brake easily. You have to pry a little at the sides of the plastic buckle cover and it will pop off. It doesn't take much, you are prying to just unhook the cover. Lift the button and spring out. Pay attension to which way the webbing is sewn at the end for when you reassemble (if you just want to wash you may be able to wash a couple of times while moving the webbing in and out of the buckle?). It is tough but you can fit the sewn/folded end through the buckle.
You can even take the whole other end apart but it is hard to put into words how to do that end.
Old 10-20-2010, 08:22 PM   #5
Thealien
Thealien's Avatar
Re: Seat belts
Didn't know if you had
Seen This Thread
