Old 07-19-2010, 02:01 PM   #26
Puglia10
Re: Project mouthful-80 c10-6.0?
well, here she is! 01 lq4 DBC with 92k, needs a good cleanin but its a start! notice anything im missing?
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 07-19-2010, 04:18 PM   #27
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
looks like its missing a belt...and a starter?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-19-2010, 06:08 PM   #28
Puglia10
What year/model starters would work? Do I need one for an 01 6.0 or would any later model chevy work, like for a 4.8 or 5.3 etc, what should I look for?
1979 c30 3+3 dually
1946 GMC
Old 07-19-2010, 06:20 PM   #29
68GMCCustom
from what I've seen they are all the same number...with possible exception to the LS7/LS9 variants. # I used was 10465385.
Kurt -
Old 07-19-2010, 07:36 PM   #30
Puglia10
Okay thanks, I was told to buy brand new instead of used to be safe? Think that's a good idea or would I be okay getting used? How much is a new one?
1979 c30 3+3 dually
1946 GMC
Old 07-28-2010, 04:12 PM   #31
Puglia10
this is what i should buy? good price too, should i grab this one right now?> http://cgi.ebay.com/ebaymotors/1990-...s#ht_500wt_877
1979 c30 3+3 dually
1946 GMC
Old 07-28-2010, 05:53 PM   #32
68GMCCustom
I wound up buying mine at Rock Auto. Its an AC Delco, but it shows to be rebuilt. I wanted "new"...but couldn't find one at the time.
Kurt -
Old 08-02-2010, 12:54 PM   #33
Puglia10
does any year 4l80e bolt up to my 01 lq4? can it be from a van or anything? what should i be looking for for it to come with, etc? thanks
1979 c30 3+3 dually
1946 GMC
Old 08-04-2010, 12:04 PM   #34
Puglia10
bump, and what needs to be done to the trans crossmember? i had to bring the rest of the truck home last night, running out of rooom so i gotta get moving putting this thing together! pics coming soon!
1979 c30 3+3 dually
1946 GMC
Old 08-04-2010, 12:11 PM   #35
Puglia10
here it is! fenders/cowl hood, rear end etc in a different truck. now i have everythinggg by itself, so many pieces
1979 c30 3+3 dually
1946 GMC
Old 08-04-2010, 01:14 PM   #36
68GMCCustom
the crossmember just needs to be slid back or up for it to match up.
on the 4L80...I remember something different about the early LQ4's ...but with an '01 should bolt up?
Kurt -
Old 08-04-2010, 04:41 PM   #37
Puglia10
okay thanks!
1979 c30 3+3 dually
1946 GMC
Old 08-23-2010, 12:49 AM   #38
Puglia10
back from the blaster! paint coming soon
1979 c30 3+3 dually
1946 GMC
Old 08-25-2010, 12:52 PM   #39
Puglia10
here it is all painted! finally a little progress
1979 c30 3+3 dually
1946 GMC
Old 10-21-2010, 12:35 PM   #40
Puglia10
Well, its been almost a month but I should be getting the frame back from the welder this weekend or shortly after, then start making some real progress! my bushings are ordered, and i bought a 4l80e out of an 06 2500hd for 400 bucks! cant wait to get started on this thing finally!
1979 c30 3+3 dually
1946 GMC
Old 10-21-2010, 12:51 PM   #41
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Sweet! Looking forward to more pics!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 10-21-2010, 12:57 PM   #42
Puglia10
Thanks bud! It's a little overwhelming trying to figure out how to put everything back together(I didn't take it apart) plus doing the 6.0 swap, but I think I'll be able to figure it out with the help of this site, it's been awesome so far! (Plus everyone keeps saying I'll never be able to do it, so I want to prove them wong!) Sweet build by the way, I've been following yours and menace's closely! Just awesome! Hopefully someday I'll be there too.
1979 c30 3+3 dually
1946 GMC
Old 10-21-2010, 05:24 PM   #43
Puglia10
So I'll need to make a decision on coils pretty soon, looking for opinions. Would you just use the originals and cut them or buy new ones? On a budget but want to do it right, so if I need them I'll get them. I just won't know how much lower I want the front to have a SLIGHT rake after a flip kit and 3in spindles, can't have my oil pan dragging but I do prefer the front about an inch lower than the front with these trucks. Maybe a 1in coil drop for a total of 4?
1979 c30 3+3 dually
1946 GMC
Old 10-24-2010, 10:59 AM   #44
mooseknuckles
mooseknuckles's Avatar
cut one coil off the springs, with the spindles that should give you what your looking for.
mooseknuckles is offline   Reply With Quote
Old 10-24-2010, 06:13 PM   #45
Puglia10
isnt one coil two inches?
1979 c30 3+3 dually
1946 GMC
Old 10-24-2010, 10:20 PM   #46
mooseknuckles
I wanted the same look on mine, and I thought of doing just a half a coil at a time, but I wasn't taking it apart again and I wanted it low anyways so I cut a whole coil off. With the spindles it was around a 4-5" drop, and with the flip in the back it was 5-6". And now it has bags in the front and as it sits it has about 7" drop, and the back has a c-notch and I moved the spring hangers up on the frame so the rear has about 9" of drop. Soon I will be bagging the rear end as well.
Old 10-27-2010, 08:59 PM   #47
Gordonr1973
Home Built '87
Gordonr1973's Avatar
subscribed...and reading while I watch the World Series!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 10-28-2010, 12:22 AM   #48
79gmcclassic
79gmcclassic's Avatar
cant wait to see this build!!
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 10-28-2010, 12:30 PM   #49
Puglia10
thanks guys, STILL waiting on the welder! > but hopefully some updates soon! at least some pics of the boxes of parts arriving at my house including rear discs!
1979 c30 3+3 dually
1946 GMC
Old 10-28-2010, 01:22 PM   #50
Puglia10
Waiting on an email back for these 20s! Wasnt in the plans because I dont have 2k for nice wheels and tires but for this price I might make the trip and scoop em up! What do you think? http://longisland.craigslist.org/pts/1993118547.html
1979 c30 3+3 dually
1946 GMC
