Old 06-14-2003, 02:03 PM   #1
CraigS
Tailgate Hardware Remove/Install -- How?
I bought a new tailgate to replace my current one with a 2 inch bow in it, end to end. How do I remove the latch hardware from the old one? I see there are 3 big phillips head bolts in the center to hold the center section, and there are two bolts holding the latch assembly on each end, but the cover plates on the end appear to be attached by a spring loaded mechanism. Anyone know the right way to do this BEFORE I just cut it open with a plasma cutter?
72 GMC K20, 454, TH350
00 GMC Yukon
66 Ford Bronco
CraigS is offline   Reply With Quote
Old 06-14-2003, 02:32 PM   #2
CraigS
Figured it out myself. Once the center paddle is unbolted, the end rods slip off and are removed thru the ends. Thanks anyway.
00 GMC Yukon
66 Ford Bronco
Old 06-14-2003, 04:29 PM   #3
griesel72
griesel72's Avatar
You got it correct. Don't be afraid to just tear into your truck to figure something out. They are pretty simple.
david
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
