Closed Thread
Old 10-22-2010, 08:47 PM   #2001
ratty 46
Re: How about some pics of 73-91 crew cabs
Very nice Joe. I'd drive the snot out of that with a lowering done to it.
I'm close to finishing my crew .... so the parts pile can get boxed & shipped.
Ratty 46
ratty 46 is offline
Old 10-22-2010, 08:53 PM   #2002
joe231
joe231's Avatar
Thanks!
And Right on!
CHEVY ONLY
joe231 is offline
Old 10-22-2010, 11:28 PM   #2003
496 chevy
496 chevy's Avatar
Originally Posted by thirdstreettito View Post
1985 K20 CCSB
454c.i. 4BBL (Performance Built) V8, Automatic (Turbo 400) Transmission, Dana 60 Rear w/ 4.10 Gear Ratio, 4 Wheel Drive Lock Out Hubs, 6 Inch Lift, P. Steering, P. Disc Brakes, P. Windows, P. Locks, Tilt, Air Conditioning, Custom Tweed Interior w/ Billet Accents, Edelbrock Performance Intake & Carb, AM/FM/CD w/ Amp & Sub, Chromed Long Tube Headers, 3in Flowmaster Dual Exhaust System, Appears to be an Original Sheet Metal Truck, 37x12.50x17 Pro Comp X Terrain Tires, 17x9 Eagle Alloy Series 101 Wheels, Gorgeous Silver Metallic Exterior, Rhino Lined, Customized into a Short Bed, Dual Fuel Tanks, Outstanding Fit & Finish, Billet & Chrome Engine Bay, Southern Truck
http://www.fastlanecars.com/public/V...-b9ac3cc01f94#
That is one beautiful truck I love the job on it I just finished mine it is a long box on 40" tires with a cummins turbo diesel in it you should check it out. again nice truck!
crew cab chevy cummins powered
496 chevy is offline
Old 10-22-2010, 11:58 PM   #2004
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline
Old 10-23-2010, 01:15 AM   #2005
firenuttz
2lo4me/ntlonuf/ntfstnf
firenuttz's Avatar
here is a crew that im gonna guarantee isnt on here yet ill try to find some more recent pics of it though
62 GMC swb fleetside~ project: still undecided
84 Chevy 4wd crew cab 8 inch lift and 37" goodyear h1 pulloffs, still rockin the old mans former plate 2LO4ME
65 chevy 1 ton panel~ bagged/bodied duramax plans slowly in progress...
02 Silverado cclb duramax~ sas'd "bro" truck with more rust than imagineable...
firenuttz is offline
Old 10-23-2010, 10:00 AM   #2006
DetroitDan
DetroitDan's Avatar
I'm a 1 ton guy, but that is a really sharp looking S-10. Don't tell anyone I said that though.
Hey do you know what the springs are in that crewcab? Putting a 4 inch in mine soon, trying to get an idea what it will look like. That looks taller than 4 inch.
DetroitDan is offline
Old 10-23-2010, 10:36 AM   #2007
joe231
joe231's Avatar
"burb frame or long bed regular cab frame?
I like it!!!
CHEVY ONLY
joe231 is offline
Old 10-23-2010, 03:17 PM   #2008
firenuttz
firenuttz's Avatar
my uncles s-10 has a 5 inch lift and the total on my dads crew is around eight inch my white crew only sits about an inch or two higher than my dads but thats because im on 35s and hes on 235 85 r16 bfg all terrains however the truck is on stock height dodge 3/4 ton springs. it just looks really lifted because he is on a different frame
here is some more pics of his truck and if you look in the background of the first pic you can see my crew cab
Old 10-23-2010, 03:19 PM   #2009
firenuttz
firenuttz's Avatar
I like it!!!
yalls my hate me for this but my dad and i put it on top of a single cab long bed DODGE frame with a cummins turbo diesel in it
Old 10-23-2010, 03:25 PM   #2010
DetroitDan
DetroitDan's Avatar
thanks, I've got 235/85/16 too, biggest I could fit. I want it to sit higher but I dont want it so high it makes the tires look too small.
Old 10-23-2010, 03:38 PM   #2011
firenuttz
firenuttz's Avatar
i thought that they looked too small on mine when i had a 4 inch lift but to each his own
Old 10-23-2010, 04:23 PM   #2012
DetroitDan
DetroitDan's Avatar
I think they're too small too, I'd much rather run a 35, but with a dually I'm pretty much limited by the 6 inch wide rims. I have 255/85/16s on my 97 dually, which are about a 33x9. They are a 1/2 inch wider than what is recommended for that rim size, but not a problem. I have seen guys run 12.50s on these rims but that is way too big imo. I could switch the 255s onto my 82, but that would require adding fender flares and I don't want to do that. The 255s are a little wider, plus I have a 1.5 inch spacer between them. So they'd be poking out of the fender more than a little. And I think that would ruin the look I'm going for with the fleetside dually, having the rear wheels tucked under. I have considered going to single rear wheels just to get 35s on it, but like I've always wanted a fleetside dually.
I love lifted trucks and ever since I've gotten into duallies it's been a source of aggravation that I can't find big enough tires. Well, I can't leave this truck sitting stock, it's too low. I already upsized from the weenie 215/85s to 235/85s and it looks better. I've already got a 4 inch lift waiting to go in. I hope it looks good. I don't want it to tower over the little tires.
Old 10-23-2010, 04:28 PM   #2013
DetroitDan
DetroitDan's Avatar
I thought there was something wrong with that picture! It seemed like the front wheels are a hair too far back in the fender well. I kept looking at that and wondering if it was my imagination, or because it was so tall, or what. Then I got comparing it to other pictures and nobody elses sits back like that. Is the front end narrower too? Almost looks like the front tires are in further.
Old 10-23-2010, 06:03 PM   #2014
firenuttz
firenuttz's Avatar
it may look goofy but the wheels are as centered as they can be, the axle is as wide as a chevy as far as i know, and for your tire problem you might want to check with interco tires because every lifted dually that i see always has some kind of swamper on it
Old 10-23-2010, 07:07 PM   #2015
DetroitDan
DetroitDan's Avatar
I ran Interco TrXus MTs in 255/85/16, best tires I ever owned! They were quiet on the highway, looked cool, unstoppable off road and awesome plowing. I was a little leery about going from a 10 ply to an 8 ply, but the sidewalls are so rugged on an Interco it wasn't a problem. Finally wore them down enough where I started looking to repace them. Well, first the price went way way up, so I was only going to replace two at a time, but then when I tried to order them I couldn't find anyone stocking them. Come to find out they discontinued them in that size. That stinks because they were fantastic tires. So I ended up replacing all 6 with Remington Mud Brutes in that size. Cheap price but I'm not real enthused. They are already getting loud, the sidewalls are really soft, and I can feel them squirming around when I tow heavy. I hope they plow good and last a while, but I honestly don't hold out a lot of hope for either.
Old 10-23-2010, 09:30 PM   #2016
BGRAFX
How about a chop top
BGRAFX is offline
Old 10-23-2010, 09:34 PM   #2017
cochino12
It followed me home?
cochino12's Avatar
did you end up getting that dually Michael? There are a few really nice ones on CL here in town
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline
Old 10-24-2010, 01:02 PM   #2018
pvkj454
The 1st gen. Dodge D60 is 1.5" narrower than the Chevy. It is narrower on the short side of the chunk.
pvkj454 is offline
Old 10-24-2010, 01:06 PM   #2019
DetroitDan
DetroitDan's Avatar
well, I cant believe I'd notice 1.5 inches. I think what it is was that first pic taken from the front, the tires look real close together. Must be because the camera was up high, the axle is set back a little, plus the 1.5 inch.
Old 10-24-2010, 02:02 PM   #2020
BGRAFX
this truck is unbelievable
BGRAFX is offline
Old 10-24-2010, 06:21 PM   #2021
rjn72
rjn72's Avatar
My crew cab. 454 tbi with rebuilt th400, dana 60 front and 14 bolt posi rear, new american eagle alloy rims with 255 85 16 tires, had a camper for years so the bed looks awesome. Truck is in awesome shape and I got a great deal on it. Freind had it parked behind his house for about 5 years and didn't want it anymore. 2000 dollars later, i drove home my new truck. He lowered it, but still had the lift springs and blocks. I am thinking that they will be going back on soon.Name:  my truck 002.jpg
Name:  my truck 003.jpg
Name:  my truck 004.jpg
JESUS IS LORD
87 crew cab V30 454/400
rjn72 is offline
Old 10-24-2010, 07:57 PM   #2022
Davidmichael
Davidmichael's Avatar
now that is very nice
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline
Old 10-24-2010, 08:53 PM   #2023
pvkj454
You got a smokin deal on on a sharp truck.
pvkj454 is offline
Old 10-24-2010, 10:23 PM   #2024
DetroitDan
DetroitDan's Avatar
rjn72, I love your truck, it's beautiful! Hope mine turns out half that pretty when I finish painting it. Now I really want to put my 255s on it, but I don't have dually fenders and I don't really want to add big flares to cover them. Always a dilemma! So are you saying that truck doesn't have any lift right now? Looks a lot higher in the front than mine. Actually your front end looks nearly identical to mine, I put the 87 grille on it but still have the 82 headlight bezels and 82 bumper.
You know, I just have to say thanks for posting these pics, this is what keeps motivating me to work on my truck.
Old 10-24-2010, 11:27 PM   #2025
mr.chevyblack
mr.chevyblack's Avatar
My crew cab. 454 tbi with rebuilt th400, dana 60 front and 14 bolt posi rear, new american eagle alloy rims with 255 85 16 tires, had a camper for years so the bed looks awesome. Truck is in awesome shape and I got a great deal on it. Freind had it parked behind his house for about 5 years and didn't want it anymore. 2000 dollars later, i drove home my new truck. He lowered it, but still had the lift springs and blocks. I am thinking that they will be going back on soon.Attachment 647687
Attachment 647688
Attachment 647689
what a deal looks good once i learn how to up load pics i will be adding some of mine crewcab
mr.chevyblack is offline
Closed Thread
crew, crew cab, square body, squarebody, squarebody.net
