Old 10-23-2010, 12:55 PM   #1
palposity
palposity's Avatar
Annoying Snag in Tranny Installation
I have an 86 K20 I'm putting together and for some reason when I attempt to install the TH400 on the back of my 350 engine the tranny comes within a quarter inch of making contact with the engine block and just stops. What gives? I checked and cleaned the dowel holes, tried turning the engine just a hair, but I can't get the stupid tranny on!
There doesn't appear to be a guide pin on the end of the tranny shaft. Can you guys think of something I'm missing?
Thanks!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 10-23-2010, 01:03 PM   #2
rjn72
rjn72's Avatar
Re: Annoying Snag in Tranny Installation
Is the torque converter all the way back?
JESUS IS LORD
87 crew cab V30 454/400
rjn72 is offline   Reply With Quote
Old 10-23-2010, 01:09 PM   #3
chevyman95
chevyman95's Avatar
^^^^^^^ Plus 1
I had that problem once and it was that the TQ wasn't on all the way
chevyman95 is offline   Reply With Quote
Old 10-23-2010, 02:05 PM   #4
palposity
palposity's Avatar
You know what I bet you guys are right. I'll try to re-seat it and see if that does the trick. Thanks. Rookie mistake I guess.
Old 10-23-2010, 02:10 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Seen it a hundred times probably over the years. At least you were smart enough to stop and ask questions. I've seen guys put bolts in and run them down with an impact until the trans case broke!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 10-23-2010, 02:15 PM   #6
palposity
palposity's Avatar
I can't believe anyone would use an impact wrench on an aluminum case. Wow. I hope I didn't do any damage to anything trying it while the TC was not seated properly. I guess time will tell.
Old 10-23-2010, 02:19 PM   #7
y5mgisi
Second Chance Program
y5mgisi's Avatar
Should be only about 1/2" betweeen the converter and the trans case. (as viewed from the bottom near the trans pan)
y5mgisi is offline   Reply With Quote
Old 10-23-2010, 09:24 PM   #8
palposity
palposity's Avatar
Yep - that was the problem. Took the tranny back off and re-seated the TC. All set now. Thanks guys! I sure hope it still works!
Posting pics in my build thread now.
Old 10-24-2010, 01:35 AM   #9
chevyman95
chevyman95's Avatar
Should still work fine as long as you didn't beat the crap out of it with a hammer or something. This stuff is tougher than we give it credit for.
