#26 |
.. !WAR FEDOR! ..
Re: Lowered 73-87 Short Beds
4.5ish closer to 5/6
"san diego chargers #1" |
#27 |
This is a lmc 4/6 with about a full coil cut off both fronts, and 2 more inches of block out back. The truck is my daily, and besides the occasional lower scrape, i have no complaints.
#28 | |
.. !WAR FEDOR! ..
![]() ![]() ![]() ![]() really dig that man. is that a stock paint?? im thinking of painting my truck a gunmetal color, i like the eraly burb dark gray.
#29 |
Slugish
![]() Join Date: Jan 2005
notch is preferable for 6in & lower , but not necessary unless you actually use your truck as a truck (hauling heavy loads etc. Am down 6.5-7 in in rear with no notch & still can carry moderately heavy loads. deepends on how many leafs also.
#30 |
Slugish
#31 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Hey Joe,... get under your truck and cut those rear u-bolts off.
![]() There can be dangerous scrubline issues with those. Oh yeah,... COOL truck!
#32 |
Thanks, it's the second coat of paint thats been on the truck. Im not sure of the name, but its an 08 gm truck color. It's a little darker and has more of a metallic look than the original.
#33 |
Well, with the full coil in the front and the 2 more inches in the back, my truck should be about a 5.5/ 8 or so. I also had to put a smaller sidewall tire in the front for wheel tub clearance, so that made it even lower.
#34 | |
Badass
and where in fl are you at
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
#35 |
i hate to do any cutting to the frame...not shying away, but perhaps something along the lines of a 3/5 combo would be the next best way to go without doing any torching to the frame. unless you can still get the 4/6 without cutting(granted it wont be a work truck anyway) decisions decisions..
#36 |
Badass
do a 4/5 it will look good. no cutting needed. but it will hit the frame sometimes when halling a load.
#37 |
.. !WAR FEDOR! ..
i like them!!! haha, just kidding. they are gone now bro. i put some leaf springs of a newer truck, and they were a 6pack, i only had 4 before, the old u bolts didnt fit so i bought some cheapy ones at pepboys in the meantime.
#38 |
Slots go on anything!
My '74 is about 6/8. I can't take the credit for the drop, as Scoti did it when it was his DD. I drive it to work a couple times a week, and it rides really well, though.
1974 Jimmy- 5.3/4L80e/NP241 |
#39 |
On a budget like Fred Sanford
Here's mine, it's a 4/4 with shackles/hangers out back and up front is 2.5" spindles and 1 coil cut off the factory springs. Tires are 275/60/15 all around. I wanted to retain a little rake and it turned out good I think.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
#40 |
#41 |
5/7 Djm springs and spindles and Flip kit
Justin |
#42 |
![]() Join Date: Mar 2008
Western 2.5" drop spindles in front and McGaughy's 4" drop hangers and shackles in rear. 15"x8" Rally wheels wrapped in 255-70s Firestone Firehawks. No issues with rubbing and the truck can still carry a load.
1986 GMC Sierra Classic C1500 SWB 2006 GMC Yukon Denali http://67-72chevytrucks.com/vboard/a...hp?albumid=977 |
#43 |
#44 | |
#45 |
#46 |
3” spindles, cut coil, flip kit. Needs a 1” shackle in the rear. Tire sizes are 215/70/15 up front and 275/60/15 in the rear.
#47 |
Here is my 74 that is a 3.0/5.0 drop. It is not a flip kit (don't like cut frames for towing), it started as a heavy half. I used 3" Belltech front spindles and 4" drop rear shackles then pulled out 3 leafs from the 8 leaf rear springs.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
#48 |
nice chevy
#49 |
My 1979 GMC I haved owned for 32 years!!!!
#50 |
Probably a 4/5 ish.
1 ton coils up front, 2 coils cut, rear has 2 large springs and bottom spring, and lowering hangers up front. ![]() Notching the rear sometime.
1980 c10 Custom Deluxe 296 inline ;] SM-465 and 3.73s Lowered and shaved ![]() My Build! |
Tags |
73-87 chevy truck, dropped, lowering, slammed |
