06-15-2003, 11:42 AM | #1 |
quick help on a saginaw 4 speed????
how do i get the tailshaft housing off the main part of the tranny? i have the sideplate off and all the bolts off and it comes out 1/4 inch or so but the gears stay with the tailshaft housing. what do i take off? thanks, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
06-15-2003, 12:00 PM | #2 |
Fabricate till you "puke"
there is an external snap ring on the rear bearing, that holds the bearing/shaft /gears to the tailhousing. if you can slide it back far enough, you might get at the snap ring(it been a while). I have always removed the tail housing with the shaft & gears, & separated the housing after. You will have a row of needle bearings on the inside of the input shaft to deal with tho.... good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
