2.5 inch Rams horn on a 72 C10?
Bought a set of 2.5 inch, straight dump, corvette rams horns for my 72 C10, 350, TH350. Two muffler shops told me the turn coming out of the manifold is too tight. I've searched the post and it seems several people have done this. Is there a technique or trick to use these? Does anyone have any pictures of how the down turn out of the manifold was accomplished?
Re: 2.5 inch Rams horn on a 72 C10?
it's old, but you might give PICKMUP a call and see if he could still help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=234622
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
The only real way to make it work is to mount the V8 in the 6 cylinder spot which should work fine. If you have ever looked at 4X4 truck, you be amazed at how far back the motor is.
#4 | |
Its a Truck Thing......
Blake,
I had the same problem, no shop would make the pipes. I put on the truck ram horns and no problem since.... Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
