But Found Her 25yrs Later!
Okay,
I'm Starting my Build Thread. ![]() I lost (sold) my 65 back in 87. I posted about me looking for it here: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 In the mean time, I bought a 66 Service Truck to Tinker on. . ![]() I still hope to find my 65, but this will tide me over. ![]() To be continued.....
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-26-2010 at 10:01 PM. |
Re: My 66 Service Truck Build Thread
The Nice Guy who sold me the truck, posted on Craigslist that he wanted $350, and if no one bought it by today, he was taking it to the wrecking yard.
![]() I called him to ask him if he was really going to take it the wrecking yard. He said he was moving, and had no choice. I asked him how much he thought he would get from the wrecking yard. He said maybe $200 - $225 He then said he'd give it to me for that. (Disclaimer - I didn't think he was asking too much at $350, just that my wife was in no way going to be happy about me buying this, and I figured $225 would soften her reaction. ![]() I gave the guy $250 because he brought it to my house. So that's the opening ticket - $250 - invested so far.
My New Project Service Truck:
1966 Chevrolet C20 292 Inline 6 LongBed Eaton RearEnd - not sure Gear Ratio. Service Bed Miles Unknown Immediate To Do List: Fix ignition switch - Project Status = done http://67-72chevytrucks.com/vboard/s...d.php?t=427476 Replace Cracked Front Windshield Project Status = Started I pulled one from a 66 at the wrecking yard for $35 Picked up a Drivers side front fender while there for $33
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 01-19-2011 at 03:28 AM. |
Running Tabulation of Costs:
$225 - Price of Truck $25 - Truck Delivered $35 - Used Windshield $50 - Complete new Ignition (Housing, Keys, Tumbler, Bezel Nut) $33 - Drivers Side Fender $10 - Heater Knobs (LMC) ___________________________ $ 378 - Total So Far
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-26-2010 at 10:08 PM. Reason: Added Fender Cost |
looks like your off to a good start
ron |
I was totally gonna buy that truck. LOL. U got a great deal. I spoke to the guy and he was really cool. You must have got in there before me. Delighted to see it here on the forum too.
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. |
The 292 Block is Cracked.
I'm debating getting another 292 or just moving to a V8.
if block is cracked/not going for for "original" then go with what you WANT
like to see this through and good luck finding your old truck subscribed and like ive seen others tell you already- beware this site becomes addicting... im a college kid and should be studying right now hahaha |
#9 | |
Here's his add as it was:
#10 | |
#11 | |
http://portland.craigslist.org/mlt/cto/2027895441.html Not sure if it's a 1/2 or 3/4 ton though.
Ignition is good now:
http://67-72chevytrucks.com/vboard/s...21#post4280921 Still looking for a 3/4 ton donor.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 11-07-2010 at 01:49 AM. |
Got both fenders cleaned up -
passenger side all hammered out and ready for filler. drivers side rust in lower part cut out, patch piece fitted and ready for weld.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 11-07-2010 at 02:08 AM. |
welded patch and smoothed out some filler on drivers fender.
Still looking for a good 3/4 ton donor.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 11-13-2010 at 02:09 AM. |
#15 |
Bought this mainly for the motor:
![]() Now I'm debating if I should make my truck a 4x4. Edit: I've now decided to just use the motor and part the rest out.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 11-16-2010 at 01:09 AM. |
#16 |
The motor in the Suburban is a 350 GoodWrench - installed 7 years ago. I don't know how many miles on it, but a clean motor.
Here is the thread I asked my question about it in: http://67-72chevytrucks.com/vboard/s...d.php?t=226879
#17 |
The 60-66 GMC/Pontiac guy....
The K member, (engine cross member?) that the suspension bolts to on the front end of that suburban bolts right to your 66 frame with 1 overall modification, you need to drill out 1 hole per side and elongate 1 hole per side after you bolt it to your trucks frame.
There are 14 bolts, 7 per side that bolt the entire suspension to the frame. It drops off in 1 complete unit. Capfab makes a nice adaptor that will let you use the steering gearbox too giving you power steering. If you have leafs the rear end is a direct bolt in. If you have trailing arms you can weld perches on the 'burbs rear housing as it is probably a better gear. (66 was commonly 3.73 or 4.11) Take a look at my build and the rear and front suspension is from a 79 and I have several other things I found will help.
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac
#18 |
Thanks,
I'm pretty positive I'm not going to use the 4x4 stuff from this suburb - it's not a 3/4 ton. I bought it because the motor is clean, and is only 7 years old.
#19 |
OHHH!!!! I didn't notice it was a 4X4.
Thats a different story. 63-66 4x4 or.... 67-72 frames are the same with the exception of the rear cab mounts that can be swapped and the first 3 inches of the frame horns that can also be swapped with a little weld work and cutting.
#20 |
Yes, if it was a 3/4 ton, I very well may have went 4x4'n.
So, I will just take the motor and the brake booster/master cylinder off this.
#21 |
U hiding from the cold? Any updates on the beast?
#22 |
Funny you should ask....
![]() Pulled the 350 from the donor today: ![]() This motor is coming out and being replaced with the 350: ![]() So yes, I'm working in the cold - got my thermo-underwear on.
#23 |
Not bad man. I know the feeling on the thermo underwear. I get the lined dungarees from bi-mart and they help alot with the cold. And they're cheap.
#24 |
The build will surely be going slow.
My goal at this time is to get it mechanically usable, and stop or minimize any further rusting. After that, I will use it as a truck for a few years, and just tinker with it. A frame up restore is most likely years out. This summer my goal is to clean up and preserve the underside of the cab. Posted via Mobile Device
#25 |
I tell you....
Now I remember why I liked these trucks so much. I had the front clip stripped from this thing in less than an hour, with pretty much nothing but a 1/2 and 9/16 socket. Yee-ha! ![]() 292 is out. Let's see what I get done tomorrow. Posted via Mobile Device
| Bookmarks |
| Thread Tools | |
| Display Modes | |
