Old 10-29-2010, 04:08 PM   #1
foosed
foosed's Avatar
Pics of 67-72s on air w/o notch
A quick search yielded no results of what i am looking for. I need pics of 67-72 swb fleetsides on air ride with no c-notch, just bags in place of coils. Preferrably with 18-20 combo or 20's all the way around. Please include wheel and tire info as well as air ride setup. Thank you and I would really appreciate it.
1970 c/10 swb (show truck)
1972 custom/10 deluxe 4x4 (restoration pending)
2011 silverado ecsb z71 (daily driver)
foosed is offline   Reply With Quote
Old 10-30-2010, 04:16 PM   #2
67cheby
67cheby
67cheby's Avatar
Re: Pics of 67-72s on air w/o notch
just bags with 20's
67cheby is offline   Reply With Quote
Old 10-30-2010, 04:28 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
You sure you had no notch at all in the rear with that picture???
a lot of that is going to hinge on overall tire height as well. Here is a 72 longbed on 17's with a "hat" on the rear bag. it's about an inch from hitting the frame rails w/out the notch.
Old 10-30-2010, 04:53 PM   #4
67cheby
67cheby
67cheby's Avatar
no notch , but no hat on the bags just a plate
Old 10-30-2010, 04:56 PM   #5
67cheby
67cheby
67cheby's Avatar
the second pic in that last set was the same exact day as the first pic i posted i think the rear tires were 275-45-20??? i think that might not be correct
Old 10-30-2010, 04:58 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
cool. Looks lower than I thought it would have been. I guess that's when it's sitting right on the frame basically? ( i know you're a "little" lower now )
Old 10-30-2010, 05:02 PM   #7
67cheby
67cheby
67cheby's Avatar
it was actually setting on the u-bolts !! and yes i am a tad bit lower now.....and if i would have stopped then i would have been driving this for the last year !!
Old 10-31-2010, 12:26 AM   #8
firedog
firedog's Avatar
Here is my truck no notch the rear bags are located in the factory spring location. I have 18" wheels on a tire about 28" tall.
Now my two cents... once you get the air bag bug you will never be low enuff and hope to notch mine this winter
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 11-01-2010, 10:46 AM   #9
foosed
foosed's Avatar
Thanks very much guys for your input. Cheby I love watching your build progress, it's come quite a long ways since you took those pics! Thanks VA for reminding me about the hats on the rear. I'm going to do what Cheby did and drill the frame. Also on the front I will be cutting the cups on the front brackets, I cant remember now what your supposed to cut them down to though. Firedog your truck is beautiful! Do you have a build thread or more pictures? As far as never being low enough.....A man can only go as low as his budget allows, and for me that aint much. Also Firedog your front end seems way low, you still runnin inner fenders? Thanks again guys for your help!
Old 11-01-2010, 05:51 PM   #10
jimmydean
jimmydean's Avatar
Not all cups on the front NEED to be cut, but the goal is to get the cup to sit flush with the arm.
This was my '69 with no notch in the rear aired out (front has cut cups and drop spindles)
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-03-2010, 08:24 PM   #11
firedog
firedog's Avatar
thanks for the compliments, there is a thread on here from when i put bags on my truck 2 years ago, the front is without inner fenders and i have chisolm lower control arms with a 2" drop pocket built into them and customized to mount the bags in them, i am not sure which bags i have in the front but they are not very big around and fit completely in the spring pocket along with 3" drop spindles
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
