Old 10-29-2010, 10:33 PM   #1
72tutone
Fuel Gauge stuck at 1/2 tank
Guys I just took out my dash bezel to replace some bulbs, and touch up the needles. Since I have put it back int the gauge needle is stuck at 1/2 tank.
I put 20$ worth in today, and the needle didnt move. I didnt want to take the chance in running out while I was out on the road, however the needle didnt move.
Everything I have read on the boards say there is tan wire going to 16pin connector or so going into the electrical board on the back. Is there anything on the back of the gauge that needed to be hooked back up?
72tutone is offline   Reply With Quote
Old 10-29-2010, 11:01 PM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Fuel Gauge stuck at 1/2 tank
sending unit?
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 10-29-2010, 11:07 PM   #3
DaSchlange
DaSchlange's Avatar
Definitely the sending unit. It always is when the gas gauge screws up. Hardly ever hear of it being the gauge itself. You might be able to pull the sending out and fix it yourself maybe its hanging up, or rusted terribly like mine was and just won't function correctly. Check it out.
DaSchlange is offline   Reply With Quote
Old 10-30-2010, 12:09 AM   #4
72tutone
Thanks guys... Believe it or not, a nut was loose on the circuit board. And soon as it tightened up and made contact with the copper ring, the gauge went to 3/4 full. Key is off and its sitting at that spot. My guess its now working.
So keep that mind, tighten your nuts
Old 10-30-2010, 12:10 AM   #5
DaSchlange
DaSchlange's Avatar
Lol, first time for everything I guess.... Can't believe you ever let your nut get that loose anyhow...
Old 10-30-2010, 02:08 AM   #6
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Good to hear you got it fixed, I thought that it was strange that it happened right after you had the gauge out. Just a note, the needle is balanced so it stays where ever it was when the key was on after you turn it off.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 10-30-2010, 05:43 PM   #7
swamp rat
swamp rat's Avatar
Rule of thumb,if something is working correctly before a person takes something apart and puts it back together it can usually be traced back to something that was overlooked, disturbed or reassembled incorrectly.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
