Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-03-2010, 10:26 PM   #1
old_1966_GMC
lincoln arc welder
i was wodering if the lincoln arc welder are any good for welding patch panels on my 65 gmc
old_1966_GMC is offline   Reply With Quote
Old 10-03-2010, 11:29 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: lincoln arc welder
Let me help
NO
turnit in for the copper and buy a small mig welder like the miller or lincoln
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-04-2010, 12:55 AM   #3
old_1966_GMC
why not whats the diffrence
Old 10-04-2010, 01:30 PM   #4
lofly'a
lofly'a's Avatar
that NO advice is very sound, take it. the heat range of arc/stick welding is too high for welding sheetmetal. you'll only burn big holes in the metal and cause more harm than good. you'd be better off using a panel adhesive than a arc welder
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 10-04-2010, 01:44 PM   #5
faribran
No....
faribran is offline   Reply With Quote
Old 10-04-2010, 02:08 PM   #6
cdowns
cdowns's Avatar
like everbody says NO
stick welder good for heavier stuff like chassis and fence posts if it works good and is paid for i'd keep for the odd heavyduty jobs
Old 10-05-2010, 12:31 AM   #7
old_1966_GMC
what about the lincoln gasless welder that they have
Old 10-05-2010, 08:11 PM   #8
lofly'a
lofly'a's Avatar
if you are referring to flux core wire welding, it will weld sheetmetal but is'nt nearly as neat and pretty as gas shielded wire welding. take some good advice (hope others will back me up) if you decide to buy a wirefeed that uses fluxcore (gasless), buy one that can be converted to gas shielding later. fluxcore weld quality is just as good (so i'm told) but the weld is ugly and very hard to clean up. the first wirefeed i had was flux-core (gasless), and i hated it til i sold it and bought a gas shielded machine. i have a lincoln 135plus (120V and you can take it anywhere) and love it for thin metals. i also have the big daddy miller 350p wirefeed which makes my old stick arc machine collect dust and spiderwebs now.
Old 10-05-2010, 11:04 PM   #9
old_1966_GMC
so can i get this gas for a mig welders then
Old 10-06-2010, 09:37 PM   #10
lofly'a
lofly'a's Avatar
yes you can get this argon/c02 80-20% mix at local welding supply store in many different sizes to suit your needs.
Old 10-06-2010, 10:42 PM   #11
72lb4x4
All electric welding including stick, MIG, and TIG are arc welding because they involve an electric arc so the OP's question isn't specific enough to answer.
For the folks who'll say I'm full of crap: http://en.wikipedia.org/wiki/Arc_welding
72lb4x4 is offline   Reply With Quote
Old 10-08-2010, 12:21 PM   #12
lofly'a
lofly'a's Avatar
for the sake of argument you are correct 72lb4x4, i was trying to clarify the difference between the different types of ELECTRIC welders. there are many, many different types of welding that fall under this title.
Old 10-31-2010, 01:36 AM   #13
old_1966_GMC
so how much could it cost out here to fill a tank up in the east bay area in calfonia
Old 11-01-2010, 07:29 PM   #14
Gobbles
Gobbles's Avatar
Depends on the size of tank, I have 110 Cubic Ft and it is $50 CAD to fill.
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 11-02-2010, 02:09 AM   #15
RichardJ
For the questions you are asking, you would do yourself a big favor to take a class on MIG (GMAW) welding. See if the local Jr. College or Adult Ed doesn't have evening or weekend classes. You will enjoy it and learn a lot.
Everyone in the class will have the same questions about equipement, even the guys that have already bought junk.
You might have a chance to learn on one or more different welders.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 11-02-2010, 02:19 AM   #16
laid_out_70
laid_out_70's Avatar
this website would answer just about any question you may have
http://www.weldingtipsandtricks.com/index.html
laid_out_70 is offline   Reply With Quote
Old 11-02-2010, 06:53 AM   #17
stich626
as far as the arc .. save it for bigger jobs
for automotive sheet metal
you want gas shielded mig..
the gas will make the weld pretty, (once you get a hang of it)
and the pretty weld is easier to grind down later.. less to grind,the less heat you put into the panel and less chance of warping it..
can u do it with out the gas,, yup..
the less time grinding the welds will more than pay for the dirrence in cost to have the gas
good luck
I have a lincoln 220volt
the 110v is handy as you can take it to your buddies house.. the 220v will use less electric power.. but requires a 220v outlet..
stich626 is offline   Reply With Quote
Old 11-06-2010, 11:28 AM   #18
old_1966_GMC
im not worry about the welding skills or how to weld i just got done going school to take collision repair classes for the last 2 years so me learning how to weld isnt the proplem i wanted to find out what was a good welder to weld patch panel
Old 11-07-2010, 09:33 PM   #19
C10longwb
Your best bet if your going to do sheet metal is to
get a 140 110v mig welder it will give you beter peniteation and less prosity inthe weld witch= less prep time If you sit there and try to
fix all the bubbles from the flux welders you'll get pissed off and say this is a waste of time. If your looking for good quality at cheep get a Hobart 140 I have the step up the 187 but I like to play around with thicker stuff like 1/4 and 3/8 you should have a fairly close local welding shop get your tank filled and supplies there get a bottle off someone local because the weld shops are expensive.. My 150 bottle was 200 and they wanted 175 for a 75... But for wire and tips and the gas it'such cheeper to go
though a weld shop good luck
C10longwb is offline   Reply With Quote
