Old 10-31-2010, 11:05 PM   #1
Slick67
Sofa King Crazy!!
Slick67's Avatar
Transmission seems to slip?
I finally got it running and the trans seems to not be grabbing like it should. Maybe it still needs to be run a little before it gets all of the fluid running through it completely? The trans worked fine when I pulled it and it was rebuilt before I got the truck. The only thing I have done to it is put a new filter in it.......and clean and paint it. Any suggestions?
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 10-31-2010, 11:32 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Transmission seems to slip?
you double checked the fluid level?
You didn't by chance install an aftermarket converter did you?
Old 10-31-2010, 11:52 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Mine will sometimes slip off-idle initially, then grab, when I try to go forward if the fluid is low. Kinda seems like that is what yours is doing in the video clip.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-01-2010, 04:51 PM   #4
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yes, maybe 4 times. It was the tc that was in the truck when I got it. It did fine before I pulled it.
I will have to check it again since I have pulled it outta the shop about 4 times.
Old 11-08-2010, 11:26 AM   #5
Slick67
Sofa King Crazy!!
Slick67's Avatar
Sounds like the trans pump has been stripped according to 2 mechanics. I didn't get the tourque converter on all of the way so I gotta pull the tranny, and get it fixed. THIS SUX!!!!!!!
Old 11-11-2010, 02:56 AM   #6
Slick67
Sofa King Crazy!!
Slick67's Avatar
I got the tranny out and let the mechanic look at it tonight. He said there isn't anything wrong that he could tell. He said put it in the truck, jack up the rear tires, and run it in reverse for a little while. I have heard of this before when a trans sits for a long time it will kind of seize. Turbo 400s seem to be a more common tranny for this issue also.
Old 11-12-2010, 12:44 AM   #7
Slick67
Sofa King Crazy!!
Slick67's Avatar
Update. IT WORKS FINE!!!!!! Got it all back in and drove it around the block for the first time today.
Old 11-12-2010, 01:59 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
After all that.... wow, didn't see that coming. Good info to know, and just glad it's working all right now!
- Mike -
RIP El Jay
Old 11-12-2010, 02:11 AM   #9
Slick67
Sofa King Crazy!!
Slick67's Avatar
Me to bro! I raised the rear of the truck and dumped in 8 quarts, let it run in reverse for a minute or two that was it! Filled it up with 2 more quarts, cause the torque converter had about 1.5 quarts in it. I was told that an air pocket sometimes will make this problem occur, and it will make it show that the tranny is full when it really isn't. So that is some really good knowledge on the 400!
