Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 06-07-2009, 10:53 PM   #1
Captainfab
60-66 Nut
Power Brake Booster Adapter Bracket
Here is the latest version of the power brake booster adapter bracket that I've been making since 1993. This bracket is fabricated from laser cut 10ga mild steel and fits 1967-'72 Chevy and GMC Pickups, Suburbans and panels and is 100% bolt on using holes already in your firewall. The booster side of the bracket has a 3 3/8" x 3 1/2" hole pattern. Boosters with this pattern are commonly found on S10's and full size pickups, Suburbans, Blazers and Tahoes from 1988 to at least 1998. Of course you will have to join the booster pushrod to your stock MC pushrod that attaches to your brake pedal. This can be done by either threading both ends and using a coupling nut, or by just welding them together once you determine the correct length.
I have had the original version ('63-'66) of this bracket on my '66 Suburban and have driven over 120,000 miles with no issues. I have also installed these on a couple of local pickups with good results as well. If you are wanting to add hydroboost to your pickup, Suburban or Panel I also offer a mounting plate for the hydroboost HERE
The price on the bare steel brackets is $59.50 plus a flat $16.25 shipping in the US. If you are located elsewhere contact me for shipping charges. You can also get this bracket in a satin black powder coat for an additional $9.00. Mounting hardware is included. This pricing is not current and up to date.To place an order post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
THE '71-'72 FACTORY BRAKE BOOSTERS ARE NOT COMPATIBLE WITH ANY OF MY BOOSTER BRACKETS
Old 06-07-2009, 10:57 PM   #2
Captainfab
60-66 Nut
Re: Power Brake Booster Adapter Bracket
More pics......
Old 06-07-2009, 10:59 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Nice part. Looks like it would clear up alot of space for us BBC guys.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 06-08-2009, 12:43 AM   #4
Captainfab
60-66 Nut
Thanks Josh
Old 06-08-2009, 09:11 AM   #5
72SWBChevy
72SWBChevy's Avatar
NIce work. I will have to place this on my list of "to buy" items. Craig
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver - SOLD
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 06-17-2009, 09:56 PM   #6
Captainfab
60-66 Nut
Bump for those having trouble finding this thread
Old 08-07-2009, 12:15 AM   #7
Captainfab
60-66 Nut
Haven't bumped this in a while......
Old 12-20-2009, 12:23 AM   #8
Captainfab
60-66 Nut
Checkout the December deal over in the 'Vendor Marketplace' HERE
Old 05-25-2010, 12:40 AM   #9
Captainfab
60-66 Nut
Bump.......
Old 05-25-2010, 02:42 AM   #10
hddavis
do you know if this bracket and the 88 to 98 booster set up will work on a 70 c10 with drums on all four
hddavis is offline   Reply With Quote
Old 05-25-2010, 11:06 PM   #11
Captainfab
60-66 Nut
Yep, no problem. You just need a power brake master for a drum/drum system. The one I use on my Suburban is a power brake master for a '67-'70 truck.
Old 05-26-2010, 03:13 AM   #12
hddavis
i read on here somewhere that the factory man drum master would work
Old 05-26-2010, 01:49 PM   #13
hddavis
do know if that is so
Old 05-26-2010, 11:50 PM   #14
Captainfab
60-66 Nut
I have not tried that. On the manual master cylinders, the bore in the backside of the piston is deeper than on a power master cylinder. So I suppose if you wanted to make a new pushrod to go between the booster and the master, it could be done. But I wouldn't mess with it. A rebuilt power master isn't that much $$
Old 06-11-2010, 08:33 AM   #15
mbrekke
if I use your bracket on a '72 will a booster out of a '92 bolt right in or will I need to modify the rod that connects to the pedal. Do I just pm you to buy a bracket?
mbrekke is offline   Reply With Quote
Old 06-11-2010, 11:01 PM   #16
Captainfab
60-66 Nut
Since a '92 full sized truck booster falls within the '88-'98 range, yes it will bolt up. The pushrod will need to be lengthened to reach your pedal. Yes, just send me a PM to purchase.
Old 11-03-2010, 11:35 PM   #17
swamp rat
swamp rat's Avatar
Is this for trucks without a booster altogether? or are the newer boosters that much better than the one on my 72?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-04-2010, 12:02 AM   #18
Captainfab
60-66 Nut
This bracket can be used with either the boosters listed, or you can use your existing booster. To use your existing booster you will need to elongate the booster mounting holes in the bracket slightly. I'm not sure if the newer boosters are necessarily better than the '67-'72 boosters, but the S10 dual diaphram boosters should help if you're low on engine vacuum. Plus the newer boosters are much easier to find in a wrecking yard if you can't afford a new booster. You can also convert to hydroboost very easily using this bracket and my hydroboost mounting plate.
Old 11-16-2010, 12:46 PM   #19
low-n-fat
captonfab what brake booster did u use
low-n-fat is offline   Reply With Quote
Old 11-17-2010, 02:33 AM   #20
Captainfab
60-66 Nut
The booster hole pattern and compatable boosters that I know of are listed in post #1 ^^^^^
Old 12-06-2010, 01:25 AM   #21
Captainfab
60-66 Nut
Recent feedback shows that this brake booster bracket will not work with the column shift when using a vacuum booster. The hydroboost should work, but I have not confirmed that yet.
Old 01-30-2011, 10:53 AM   #22
Greywolf200
Hello Captain, it's me again, lol,
What source vehicles have the small 7" and 8" dual diaphram boosters that work with your adapter?
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 01-31-2011, 01:52 AM   #23
Captainfab
60-66 Nut
I'm not aware of any OEM applications with 7 or 8" boosters that will work. You'll probably have to go with an aftermarket booster, and elongate the mounting holes slightly.
Old 01-31-2011, 05:49 AM   #24
Sultan88
diagnostic
Spam
Sultan88 is offline   Reply With Quote
Old 02-08-2011, 04:31 PM   #25
tubbedII
needs more $$$
tubbedII's Avatar
Is this something that can be clearanced in the bracket, or does the shifter hit the booster?
I've had this on my list of "to-buys", but now it looks like I can't...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
