Old 11-04-2010, 01:04 AM   #1
bobber80
62 tranny crossmember ????
Hay guys Im in need of some info I have a 62 chevy swb with the granny four speed on the floor and im trying to gather all the parts to do a auto tranny swap but I cant find any aftermarket crossmembers thay all start at 63 and up no 62 whats the diferance in the years can thay be made to fit with some tweeking what are you guys using in the later year trucks..
Any info you guys can send my way would help alot Thanks
bobber80 is offline   Reply With Quote
Old 11-04-2010, 01:13 AM   #2
slepysal
slepysal's Avatar
Re: 62 tranny crossmember ????
maybe this will help http://www.persh.org/pickup/700R4.htm
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-04-2010, 01:25 AM   #3
Captainfab
60-66 Nut
The big difference is the '60-'62 frames have the big 'X' in the middle whereas the '63 and up don't. So to use a '63 and up trans crossmember in a '60-'62 frame, it will need to be cut down considerably.
Old 11-04-2010, 09:43 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Here's a link showing what the factory 60-62 automatic trans crossmember looks like. Knowing where it goes might help in fabricating a replacement. They also show up on ebay every now and then.
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
Old 11-05-2010, 12:54 AM   #5
bobber80
thanks for the replys I knew you guys would have some good info now I just have to get the old crossmember out it doesnt look fun...
THANKS
Old 11-05-2010, 07:38 AM   #6
skysoldier173rd
skysoldier173rd's Avatar
swapped a 700r4 into my 60. It also had the old 4 speed before. Pictures of the
crossmember i fabbed can be seen on my site at:
www.picturetrail.com/skysoldier173rd
skysoldier173rd is offline   Reply With Quote
Old 11-05-2010, 08:29 AM   #7
lakeroadster
Jegs has universal crossmembers....
http://www.jegs.com/p/Jegster/Jegste...44017/10002/-1
lakeroadster is offline   Reply With Quote
