Old 11-04-2010, 08:54 PM   #1
GaryM
Preping frame for Powdercoat
So getting ready to tear down my 69 C10 step and want to know what you all do when preping to go and get sandblast and powdercoat done.
I was reading on one of the build pages in the forums that the person nocked out all the old rivits. My guess is that they must replace them with new G8 bolts and hardware. Any thing else that needs to be keep in mind when doing tear down.
Oh I will be doing a build thread also
Gary
GaryM is offline   Reply With Quote
Old 11-04-2010, 08:58 PM   #2
trkfrk
trkfrk's Avatar
Re: Preping frame for Powdercoat
great question?? why would you take out the Rivets? what are you gaining?
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 11-04-2010, 09:11 PM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Just make sure you have everything done with your frame before you PC. That's what I remember a friend said when he did his rock crawler frame and needed do more mods after the fact.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-04-2010, 09:49 PM   #4
msgross
msgross's Avatar
One reason for taking out the rivets would be to get to trapped rust under the frame parts (spring hangers, shock mounts etc..) It's a lot of work but worth it in the end. I took out about half of mine, wish I did them all now.
Make sure you take 100 measurements so that you can get it square again when you put it back together. I purchased all of my grade 8 hardware from Tractor Supply, they sell it in bulk...
Also wouldn't hurt to degrease any heavy spots so the sandblaster won't take as long (time=$$)...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-04-2010, 10:07 PM   #5
GaryM
Think I will be removing all the rivets on my frame. I have been welding for a living for almost 10 years now so have lots of exp at keeping things squar and true in the end..
Think it would be cheeper when time to blast and PC the frame because no crazy corners to get clean.
Gary
Old 11-04-2010, 10:14 PM   #6
trkfrk
trkfrk's Avatar
Gary
are you going to PC it in pieces? whats going to happen when you put it back together and your not metal to metal? I am not trying to sound negative!!! just trying to understand the advantage of getting the rust under the rivets verse the actual intergity of the frame.
Mark
Old 11-04-2010, 11:39 PM   #7
GaryM
I dont see how haveing PC between the frame rails and crossmembers will be an issue if the bolts are tight with locking nuts or washers they should not work free or rub.
If you buy a cross member from CCP they powdercoat them, do they leave the area where it mates to the frame uncoated. you would not think so that is a place where rust can form.
Gary
Old 11-06-2010, 12:50 AM   #8
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
I did a frame for my Typhoon several years ago - prior to having it sandblasted I took it to a professional pressure washing service and had them blast it - I think they charged me $35 and it got 99% of the oil and grease and scale off. Then had it blasted and PC - still looks every bit as glossy 5 years later.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 11-06-2010, 07:25 AM   #9
cdowns
cdowns's Avatar
talk to the shop that will b doing the powdercoatering b4 doing anything// i know alot of the highend places will burn the frame to prep for coating and there is no need to remove rivits if that is the way it is preped
