Old 11-06-2010, 09:10 PM   #1
Ilike 72"s
Is this a 67 327?
I'm looking st a parts pickup that the guy say's has the original 327 in it? My gut feeling says not so. Can you tell me. I'm not seeing a suffix code like most have. The number in front of the head is #MA06289.
Thanks, Dennis
Ilike 72"s is offline   Reply With Quote
Old 11-06-2010, 09:20 PM   #2
truckdude239
truckdude239's Avatar
Re: Is this a 67 327?
is that the code on teh back of the block or the front the one on the back is what tells
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-06-2010, 09:22 PM   #3
truckdude239
i will also say a stock 327 in 67 had and oil filler tube in the intake
David fuller
2000 Tahoe 5.3l 378
Old 11-06-2010, 09:37 PM   #4
Ilike 72"s
The filler tube missing is what I was worried about.
The number is from the pad in front of the passenger head. Shouldnt it have a prefix showing what plant, then the date, then the suffix showing the group. Or was it differant for 67
Old 11-06-2010, 09:40 PM   #5
Ilike 72"s
The spid shows it came with a 327, Tach, buckets, tinted windows, 4:11 rear etc
Old 11-06-2010, 09:55 PM   #6
292farmer
292farmer's Avatar
omg what was this truck used for?! ive never seen a motor so filthy with oil and grease! definitely looks dirty enough to be original
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 11-06-2010, 10:02 PM   #7
JCD
JCD's Avatar
MA codes as the following.
MA 1958 283 H.D. m/t 160 2 trucks
MA 1963 283 Powerglide 175 2 trucks
MA 1967 327 manual trans. 210 2 Camaro
And unless I'm incorrect.. "M" suffix was for GM of Mexico.
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 11-06-2010, 10:21 PM   #8
Ilike 72"s
J.
Yes I found these MA codes also. But--that would be if MA was after the numbers. Does this look like a restamp from a rebuild?
Old 11-06-2010, 10:52 PM   #9
JCD
JCD's Avatar
Maybe a replacement block?
1971 Demon 340
1969 SS El Camino
Old 11-06-2010, 11:15 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
It definitely has 43 yrs of grease on it!
WIDESIDE72 is offline   Reply With Quote
Old 11-07-2010, 12:07 AM   #11
Ilike 72"s
I want the 67 327 for another 67 with the wrong engine. It has a 350. I could take a chance it's a 67 engine, buy it and sell the other part's off the pickup to cover the purchase price. I'll know the engine's year from the date stamp on the backside.
Old 11-07-2010, 09:54 AM   #12
What does the harmonic balancer look like?It definitely has had the intake and valve covers changed because it has a pcv valve,too.Isn't it supposed to be in the front on the left side,like the vc is flipped?Not sure about the codes with none in front of me,but what would be a correct suffix?I can almost detect a "T" there.Couldn't say why it's not stamped clearly and it could (very likely) be my imagination.
Old 11-07-2010, 10:52 AM   #13
Ilike 72"s
Special-k,
Your right. I can see PVC in the picture now.I didn't look at the ballancer and it's 100 miles away. Also ite water pump almost looks like a long style. I think that started in 69.
Still might be an ok buy at $700
Old 11-07-2010, 11:45 AM   #14
raycow
You want to see a PCV connection on the top of the block BEHIND the intake manifold. If you don't have that, the engine is 68 or later. Btw, the PCV on the block doesn't guarantee that you have a 327, only that the block is 67 or earlier.
For positive verification that you have 327, you will need to see the casting number, also on the top rear of the block behind the intake.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-07-2010, 12:15 PM   #15
Ilike 72"s
Thanks Ray
