Old 10-24-2010, 01:15 PM   #101
67C10BUB
67C10BUB's Avatar
Re: '67 5.3L Build Thread
Originally Posted by jasonhall View Post
How much $ for the fuel tank ??
$591 shipped.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 10-24-2010, 01:19 PM   #102
67C10BUB
67C10BUB's Avatar
Originally Posted by GCncsuHD View Post
Hmm, he marked mine when he sent it.
Love the build man, I need to get rockin on mine.
I'm sure he didn't lose your order either. He misplaced mine, so after waiting over a month and a half he put a "rush order" on it. He must have forgotten to mark mine in his haste. Hopefully that's all he forgot to do.
67 5.3L Build
Old 10-26-2010, 02:02 PM   #103
big dump
big dump's Avatar
This is looking great! Are you keeping a tally or spreadsheet with all the costs? Anxious to see what this ends up being when you're finished, I'm sure it'll be worth it..
big dump is offline   Reply With Quote
Old 10-26-2010, 05:44 PM   #104
67C10BUB
67C10BUB's Avatar
No, I'm not sure I want to know. I do have a binder with all of my schematics and receipts, but I don't want to add it all up.
67 5.3L Build
Old 10-28-2010, 06:40 PM   #105
mrhino
Yea, You probably don't want to know at least till your done. once I went over my budget, I never looked at my spread sheet again. I suppose I will have to when I'm done though.
mrhino is offline   Reply With Quote
Old 10-28-2010, 10:49 PM   #106
cagodinez
cagodinez's Avatar
Very nice truck bro.
cagodinez is offline   Reply With Quote
Old 10-29-2010, 09:49 PM   #107
67C10BUB
67C10BUB's Avatar
Here are some pics of the finished gas tank install. I used stainless 1/2" bolts to mount it. Here is a pic of the fuel pressure reg and filter assy out of a Corvette. I purchased the whole setup, with AN fittings, from PACE auto.
67 5.3L Build
Old 10-29-2010, 09:51 PM   #108
67C10BUB
67C10BUB's Avatar
Here is a few pics of the LED lighting I added to the gauge bezel and glove box. They lok really cool in person.
67 5.3L Build
Old 10-29-2010, 10:02 PM   #109
67C10BUB
67C10BUB's Avatar
I STARTED MY TRUCK FOR THE FIRST TIME TONIGHT!!!!!
There was much rejoicing that it actually ran!!! I was so excited. My only issue is that the radiator is leaking all of a sudden. Sucks that I just got it put together and now I have to take it apart again.
Anyway, here is a pic of the computer install and another look at the motor in running condition. I still need to clean up some of the minor wiring, but overall, it's pretty much done. I still have a long way to go before I can drive it, however. I need to have my drive shaft slip yolk switched out, install the lowering kit and new disc brake kit, wheels/tires, etc. So, check back often. I move fast and post my progress nearly every weekend.
I also forgot to mention that I made a bracket and mounted the throttle pedal. I'll try and get pics up soon.
67 5.3L Build
Old 10-29-2010, 11:02 PM   #110
faribran
very nice build... i will be starting on mine soon.... am sure i will have some questions for you.
faribran is offline   Reply With Quote
Old 10-29-2010, 11:31 PM   #111
VA72C10
VA72C10
VA72C10's Avatar
Congrats on getting it started!!!
Old 10-30-2010, 08:54 AM   #112
mrhino
its a tremendous moment, isn't it.
Old 10-30-2010, 10:08 AM   #113
67C10BUB
67C10BUB's Avatar
Yes, I think a tear almost came into my eye I was so happy!!!
You just never know how things are going to work out when you re-wire an entire vehicle. All of my gauges and lights even work correctly. I am so excited.
67 5.3L Build
Old 10-31-2010, 03:46 PM   #114
rcrahn
rcrahn's Avatar
Congratulations on firing up your project!
You are in the home stretch......
rcrahn is offline   Reply With Quote
Old 10-31-2010, 08:20 PM   #115
67C10BUB
67C10BUB's Avatar
Thanks for the words of encouragement. It feels like I still have a long way to go.
67 5.3L Build
Old 10-31-2010, 09:21 PM   #116
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
well...... it's running, lets see a video, love this build, probably rude not to hahaha
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 11-01-2010, 12:16 AM   #117
67C10BUB
67C10BUB's Avatar
Once I get the radiator fixed and put back in I'll post a video.
67 5.3L Build
Old 11-03-2010, 06:14 PM   #118
72mike
What did you end up doing for the transmission cooler lines and fittings?
What size did you say the output of the tranny and radiator lines? I haven't looked at mine in a minute so i can't remember if its male or female coming out of the transmission. I have been reading everyone's comments and feed back trying to piece this all together but somewhere along the way i got lost. I'm a wrencher not a reader. I would like to simplyfy it and just run a briaded -6 line between the two, just need to know what the connection is on both ends.
Thanks for your help.
Mike
I researched all of the parts needed to hook up the trans cooler lines as described above. The total comes out to $107 plus shipping for all of the parts and the 37 deg flare tool. I'm still weighing it out, if I want to spend the money or use my idea for now and plan on replacing it in the future. If anyone wants to do it here is the Summit parts list:
P# Qty needed
EAR-581806ERL 1
EAR-581906ERL 1
FRA-481506 2
SUM-220690 4
SUM-230606 1
EAR-991907ERL 2
EAR-581905ERL 1
EAR-581805ERL 1
These parts are what I have found to be needed to hook up 4L60E cooler lines to the factory radiator.
72mike is offline   Reply With Quote
Old 11-04-2010, 05:33 AM   #119
67C10BUB
67C10BUB's Avatar
I ended up going to mu local hydraulic hose shop and having some 2-wire hoses made for it. They were much cheaper and screwed right in. They had the inverted flares on one side and the compression fittings on the other side to slip right over the hard lines coming out of the trans. I don't recall the sizes, but if you look up the parts on that list you will find some flare nuts that are the correct sizes. Hope that helps.
67 5.3L Build
Old 11-07-2010, 08:33 PM   #120
mcbassin
Still Learning
mcbassin's Avatar
This is another awesome project! I will be following the progress.
Old 11-07-2010, 08:52 PM   #121
67C10BUB
67C10BUB's Avatar
Here is a pic of how I mounted my gas pedal. I took a piece of 3/16" thick 3"x 36" steel from Home Depot, cut it into a 3"x3" piece and a 3"x5" piece, and welded it together once drilled for the fire-wall (old gas pedal mount)/pedal and positioned correctly. I used 2 different pieces so I could fine-tune the mounting position. It worked out great and is in a very comfortable position.
67 5.3L Build
Old 11-20-2010, 07:24 PM   #122
67C10BUB
67C10BUB's Avatar
Here is a video of the motor running open header. Kinda' loud, but it sounds pretty good. The tach is off because I just found out that you have to set Auto Meter gauges to the 4 cyl setting or it to show correctly using the ECM tach signal.
67 5.3L Build
Old 11-20-2010, 07:45 PM   #123
mrhino
That sounds good, nice rumble
Old 11-20-2010, 08:14 PM   #124
67C10BUB
67C10BUB's Avatar
Thanks, it's nice to hear encouraging words. I think that I am going to have the injectors professionally cleaned. The idle is a little irregular and the throttle response seems a little slow. Hopefully that will fix the issue.
67 5.3L Build
Old 11-20-2010, 08:28 PM   #125
mrhino
mine sound just like that, it would be perfect but it just needs the volume toned down a little. Do you have mufflers pick out?
